vw polo 1.9tdi pd100 or pd130 fuel inlet and return line from fuel filter
- Kingshill1@
hey guys
does anyone maybr havr pic or something showing the inlet and return fuel lines from the fuel filter perhaps? u wane do diesel purge but not 100 sure of the return and inlet pipes there.
Vw Polo 1.9tdi
stage 2 map wulfchiptechnic
63mm streight pipe
63mm downpipe
front mounted intercooler
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Re: vw polo 1.9tdi pd100 or pd130 fuel inlet and return line from fuel filter
U either pull out the fuse for the fuel pump (15A fuse iirc it's number 41 or 43) or connect the 2 pipes together as shown in red.
Yellow arrow is the return line, this would just be flowing back into ur purge bottle, from the metal rail.
Green arrow is the feed line to the tandem pump, this must also be in the purge bottle, i prefer putting an in line fuel filter on this pipe just incase any crap gets sucked in (the petrol filters work)
- Kingshill1@
thanks man appreciate it. was wondering this helps alot
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
No problem, it takes about an hour to purge and remember u need to vary the rpms while purging
- Kingshill1@
ok cool yeah saw video of this bit was for another vw outputs was bit different this is why wanted to know for the polo connections. but cool thanks man i will remember this.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
Re: 74kw to 96kw turbo drive untill remap
hey guys
ok installing next week the 96kw turbo into my 74kw and then remap again after that. but remap is only day or 2 after it can i still drive ok with the 96kw turbo on my current map stage 2+ just wane find out till i get new map done.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
U can, the car not gonna be faster without a remap so don't drive it hard
- Kingshill1@
ok thanks man just wanted to confirm this.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
video showing the puffing sound with the normal turbo whistle//cloud.tapatalk.com/s/5bead15105f ... 152739.mp4
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
fuel system rate flow//cloud.tapatalk.com/s/5bead6c8683 ... 155059.mp4
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
