Mk2 16v rack end/tie rod replacement
hennie71
Post by hennie71 »
Hey guys.
1988 Mk2 16v jetta with power steering. How difficult is it to replace the rack ends/tie rods? .
Must you remove the whole steering rack like the Haynes manual says?
Or is there another trick to replace it without damage to the steering rack?
Advice will be appreciated. Thanks.
Re: Mk2 16v rack end/tie rod replacement
There is a tool specifically to undo those nuts which makes it easier to do. But hell either way.
hennie71
Post by hennie71 »
Thanks Panic. In that case I'll send it to the professionals to get the job done. :thumbup:
