Hi guys,
I would really appreciate some advice, my girlfriend drives a 95 Golf 3 CSX, its a 1.8l Carburetor.
On Saturday she had no choice but to drive through a large water patch and a little while later the car cut off and hasn't started since. I am not very mechanically knowledgeable but I do know a little. So what i did try so far is to remove the distributor and try to get it as dry as possible and I also sprayed some electrical lube spray on it, also dried off the coil but still no luck...
Could someone please help me out with some advice on this matter as I am at my wits end.
Thanks in advance,
T
Golf 3 CSX Not starting...
- Membership No: 2033
Re: Golf 3 CSX Not starting...
Does it swing over? Have you checked for spark? You remove the distributor cap, right? Not the actual distributor......
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Yeah it does swing over just doesnt start and yes I did just remove the cap
- grease monkey
- Car Make: Golf
- Car Model: MK2
Did you remove the plug on the side of the distributor and dry it out?
Most common failure on those after water is failed coil.
As always - diagnose diagnose diagnose.
Pull the centre lead out of the distributo. let it lie on the motor near metal - crank and see if there is spark jumping. Don't hold it as it might get exciting
I did this once
HOWIE-WP,
