Alternator max rpm? Fan explosion
- grego
- Registered for: 19 years 3 months
- Car Model: Caddy 2.1 16V ITBS
- Membership No: 1518
Hi,
I took my caddy for a Sunday drive yesterday.
While giving it some stick an almighty bang erupted from the front end, followed by my grille flying off and into the windscreen.
This happened at around 7300rpm.
There was no loss of power, but there was a scraping sound coming from the engine bay afterwards.
Pulled over at the next safe opportunity to check.
Turns out the metal fan on the alternator (external) had exploded... Smashed the front grille, severed the bonnet release cable, huge dents in the valance and front edge of the bonnet.
A piece had also got stuck between the crank pulley and lower timing belt cover, puncturing the cover and chowing the outer edge of the cam belt in the process.
Got off very lucky! Damage could've been way worse.
Has anyone experienced this before?
What is the max rpm that an alternator can handle?
Should i need to change pulley ratios to reduce the alternator speed if revving the motor to 7800rpm?
Look forward to hearing your thoughts on the matter.
- grego
Re: Alternator max rpm? Fan explosion
smashed valance and severed bonnet cable
fanless alternator
valance front
destroyed grille
missing piece
bonnet damage
fanless alternator
valance front
destroyed grille
missing piece
bonnet damage
Maybe just a weak park somewhere.
There are Datsuns in Australia that frequently see 8000rpm around tracks. I know they change ratios on the water pump pulley for this but it is more to prevent the water pump impeller spinning too quick to flow the radiator water.
Main problem will come in if the alternator will still charge at idle and low rpm if you change the ratio. You will have to change so much on the ratio that I think it will have a impact on charging at idle in high traffic.
Is this a dedicated track car?
1977 Datsun 1200GX
Wife's car: 2019 Suzuki Ciaz
1977 Datsun 1200GX
- Membership No: 2033
On most of the Challenge race cars, we fit oversized pulley to the alti to reduce the rpm of the unit at high engine revs.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
This might have been a bad fan with a crack from long before. You were lucky, with the amount of damage you had. Coukd have been worse.
As Howie said, a larger alternator pulley reduces rpm on alternator for high reving motors. This does affect the idle charging. I’m sitting ina similar situation, where my nain crank pulley is smaller (100mm) diameter, thus turning water pump and alternator slower. On idle, I get the battery light blinking and going off over 2000 rpm. Idle charge voltage on mine is around 12,4v and not over 13 volt. This will in idle traffic cause a drain on battery. Water temp seems to be the same as with the std crank pulley.
- grego
Hi guys,
The car is a weekend toy, not my daily drive.
Changing pulleys could work, but would rather avoid that I possible.
Does anyone have experience running the alternator without the fan? Can it be done?
- ICE King
Some alternator's has fans while other's don't, the alternator's with alot of vents in the casing allows air to flow through it and in turn cool it down with out the need of a fan.
Your alternator looks pretty sealed hence there was a fan.
Considering your motor rev's high , I doubt your alternator will last without a fan. I wouldn't risk it
Why? It will solve your issue, and the resultant charging issue (related to low rpm) is moot as this is a weekend toy.
HOWIE-WP,
Go to an engineering shop and give them your current alternator pulley and ask them to increase the diameter size by 20%, 50mm to 60mm. Install with a new steel fan and Bob’s your uncle.
Don't know the price of these things, but for engineering costs and steel fan fitment, can't he maybe look for one of those fan less alternators and then install that?
1977 Datsun 1200GX
1977 Datsun 1200GX
What was the outcome of this? Is this fixed now?
