Mk 4 central locking only unlocks driver's door
My Golf 4 has picked up a problem with its central (un)locking. The driver's door still works normally on the first press on the unlock button, but the second press doesn't unlock the other doors anymore. The indicators give 2 flashes, and I hear some activity in the doors, but none of them, including the boot, unlock. I have to use the unlocking button in the driver's armrest. This button is, in itself, dodgy, and sometimes has to be pressed hard.
I do know that some of the micro switches in the door locks are not good anymore, especially the passenger door, which doesn't give a signal when open (interior light doesn't work when it's open, and if I only open that door, the car re-locks itself after a minute). But in spite of that problem, up to now, the second click on the remote was working normally.
This morning I wanted to access the boot, so I pressed the remote once, to deactivate the alarm, then manually unlocked the boot. So far so good, but when I then started the engine, the alarm gave me a one-second buzz, presumably because the boot was "improperly" unlocked. Irritating...
I'd appreciate any advice on where to start tracing the problem. Does the central locking have an error register that could be diagnosed on VCDS?
Re: Mk 4 central locking only unlocks driver's door
Yes central locking will report faults that can be scanned and that will be the best place to start.
- Car Model: Mk2 GTS
Check the earth wire as well.
S4 2004 --> Stock
A3 2010 1.8T Cabrio --> Stock
Previous
Golf Citi 2.0 8v MP9 2007
Jetta 4 V5 10V
Honda CB400 '74
S4 2004 --> Stock
Previous
Jetta 4 V5 10V
Honda CB400 '74
Thanks, gents.
Not sure which specific earth wire to check, but I'll try to follow up.
Stephan, I'll contact you re. fault scanning - need to come visit anyway, as my turbo is on its last wing and the new one needs to be installed before the old one blows completely.
All good. Lemme know when you need it done. October is crazy. Sort of mid november we are looking better.
Thanks! My October is totally crazy too. Mid Nov. sounds perfect. Will be in touch. (See also my turbo thread from today.)
- Car Make: Nike
Take Battery Terminal off for 1 our en refit. Common Problem on the MK4 chassis. Had it a few times on diff cars.
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
Now that would be a wonderfully easy fix. Shall try it immediately!
Dankbaar.
Dankbaar.
I didn't try this immediately, as I wanted to finish my fuel tank first. I always compare my actual consumption with the calculated one, and I wanted to try and squeeze 1000 km from this tank (got to 985...)
Anyhow, I disconnected the battery yesterday, and this did the trick! The second click on my remote is back to normal. Baie dankie, Rudi, jou doring.
- Car Make: Nike
Wow that is some Granny skills there, Most I got from min was Arround 800km on a Tank.VAG Fan wrote: ↑Tue Oct 23, 2018 9:17 amI didn't try this immediately, as I wanted to finish my fuel tank first. I always compare my actual consumption with the calculated one, and I wanted to try and squeeze 1000 km from this tank (got to 985...)
Glad is worked for you. Easy fix for something that is a big irritation.
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
Well, I FORCED myself to drive like a granny, was on my way back from the coast, where I had picked up some turbo noises (probably the turbine is starting to rub against the housing). So I disconnected the N75 to keep the VNT open, in low-boost mode, and took it veeery gently... Had no fun, no fun at all, crawling from KZN back to Pta at 105 km/h, up van Reenen's at 70...
On normal long-distance drives, I get about 900-950 on a tank - in town, 800-850.
