Greetings Gents,
I trust that you are well. I have a problem hehehe.
I just change my PS Pump 2 days ago. Did it to the book, bled all the air out ect ect. So the whining is gone, a lot quieter. And when I drive from cold in the morning its ok.
HOWEVER!!!! Once i have driven for a bit, lets say 15km, then it goes stiff again, especially in tight spaces. I will go as far as say that if feels like there is some resistance from the steering.
What could be the issue?
Thanks in advance.
Jetta 4 1.8T AUQ: Random Stiff Steering when hot
- Teddy132kw
- Car Model: Jetta 5 1.9TDI BXE
Re: Jetta 4 1.8T AUQ: Random Stiff Steering when hot
Did you use the right fluid?.
- Teddy132kw
Hey Panic
I used that bilstein fluid from GW. I friend of mine uses the same on his 1.8t
All good. Maybe the rack is on the way out?
- Teddy132kw
Quite possible boet. Did my usual trip yesterday and all was well even after driving +20kms. Narrowing it down to hot weather. But just wondering if there is such a big difference in the engine bay between normal running temp on a hot day and normal running temp on a normal day like like night, which wasn't cool, but was not hot.
Edit: Posted to wrong thread, sorry.
