Overfueling
Overfueling
Yes gents urgent help needed
Golf mk1 1.4i citi.com 2005 model
At first my car started than idles for 2 seconds then died, i took it to a mechanic he told me my computer box was blown. He replaced the box with another 1.4i computer box then the car started and drives but now my car overfuels heavy
Re: Overfueling
Probably a faulty coolant temp sensor or Map sensor
Re: Overfueling
Or the incorrrect map is loaded on the box.
Re: Overfueling
Thnx so where can i go to get the right map loaded because i already replaced map+ temp sensor still no luck can you tell me if all 1.4i boxes are the same ?
Re: Overfueling
No clue of location so how do we refer you? assume you are in pretoria?. So there try this guy - trevor greene -083 309 5033.
Re: Overfueling
Somerset west sir
Re: Overfueling
well that is gonna be tough. Maybe the cape guys can assist.
Re: Overfueling
Maybe try a vcds scan, when entering the engine control unit - it tells u whats loaded on the box either 1.4, 1.6 or a custom chip (unless the person who chipped it did not rename the chip)
Worth the try
Worth the try
Re: Overfueling
Ok thnx guys wil give it a try
Re: Overfueling
Trevor Green is currently situated in Pretoria, Moot Street next to Quantro auto spares and contact details are correctpanic-mechanic wrote: ↑Fri Oct 05, 2018 11:11 am No clue of location so how do we refer you? assume you are in pretoria?. So there try this guy - trevor greene -083 309 5033.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Re: Overfueling
This sounds like a broken tb...cameronclark234 wrote:Yes gents urgent help needed
Sent from a phonebooth in Hillbrow
