My Polo Cross2011 cannot start
Mantlo
Post by Mantlo »
Hi, my polo cross 2011 model can only turn On the Ignition, but not start and i checked with the Electrician and they said its not Starter nor Battery. I can only start with a push
Ashveer03
Re: My Polo Cross2011 cannot start
Post by Ashveer03 »
I guess the car doesnt crank..
U rather change ur electrician, because the problem is not the starter or battery he cant figure it out..?
Check the starter relay or ground cables
Possibly the ignition switch?.. Have you jumped the starter in the engine bay rather than using the key. Does the motor crank. I think you need a better mechanic
Mantlo
Post by Mantlo »
Thank you so much guys for your advice. I also doubt it is an Ignition because sometimes it Starts after few clicks.
does it go click when you turn the key but no swinging?.
Does the lights dim on the dash.
1) click no swing but no lights dim - starter / solenoid
2) click - no swing but lights dim - battery.
