Keihin carburetor
- Car Model: 2013 Polo Vivo 1.4 CLP
Keihin carburetor
Hi how can I adjust the keihin carburettor on the Citi golf to run slightly rich. What screws to turn.
Current : 1995 Citi Golf 1.6 carb
Re: Keihin carburetor
So you have to put a larger jet inside the carb. It's not a simple turn of a screw.
- Dub rox
- Car Model: Citi sport 1.4i
[https://img][https://img] englishKhiba wrote:Hi how can I adjust the keihin carburettor on the Citi golf to run slightly rich. What screws to turn.
Menu Back to top
keihin carburetor; individual parts - Golf(GO) [EUROPA 1982 year]
[https://volkswagen]
№part codetitleicarburetor versions15 129 025 AEM 25 129 025 MEM 37 129 015 BHN 47 129 015 THN keihin carburetor
individual partskeihin carburetor-027 129 015 Tkeihin carburetor keihin carburetor
individual parts(1)026 129 061 Dvacuum unit
for carburetor: 2026 129 062 Avacuum unit
for carburetor: (2)035 129 062 Bvacuum unit
for carburetor: 3055 129 202 Afloat needle valve set (4)035 129 289hexagon bolt
for carburetor: (5)026 129 343 Ethrottle lever
for carburetor: 5A055 129 343 AGchoke lever (6)035 129 347idling speed limitation screw
for carburetor: (7)035 129 347 Bstop screw
for carburetor: 8035 129 391float with pin 9055 129 405 Pmain jet
for carburetor: (9)056 129 405 Cmain jet
for carburetor: 10049 129 405 Emain jet (11)026 129 410 Aenrichment valve
for carburetor: (12)026 129 413idling cut-off valve
for carburetor: (13)026 129 427co-adjusting screw
for carburetor: 14055 129 433 Femulsion tube 15055 129 433 Gemulsion tube (16)049 129 435 Bidling jet (17)056 129 435air correction jet
for carburetor: (18)026 129 435air correction jet
for carburetor: 19055 129 445 Asealing plug
for carburetor: 20049 129 450 Aaccelerator pump
for carburetor: (20)026 129 450 Aaccelerator pump
for carburetor: (21)026 129 476lever - pump
for carburetor: 22no longer available23N 0141313fillister hd. bolt
for carburetor: 24N 0120053spring ring 25N 0141228fillister hd. bolt
for carburetor: 26N 0120043spring ring
for carburetor: 27N 0141335fillister hd. bolt -026 129 280gasket set
for carburetor:
Sent from my VFD 1100 using Tapatalk
- Dub rox
- Dub rox
https://goo.gl/images/ub2YZADub rox wrote:Or check out the linkDub rox wrote:[https://img][https://img] englishKhiba wrote:Hi how can I adjust the keihin carburettor on the Citi golf to run slightly rich. What screws to turn.
Menu Back to top
for carburetor:
https://volkswagen.7zap.com/en/rdw/golf ... 129-30000/
So the itmes you need to change is 10 and 9 but you need to check what the fuelling does under load on a dyno.
