Golf 5 GTI 2009
- Car Model: MK5 GTI
Golf 5 GTI 2009
Hi guys, any help would be appreciated, got my Mk5 GTI idle is the way it should be but when i drive theres no boost, no warning lights, cant feel any leaks any advise
- Titleists
- Philosopher STIG
- Car Model: 2016 Golf R
- Membership No: 1520
Re: Golf 5 GTI 2009
Have you checked the DV?
Re: Golf 5 GTI 2009
Is there any way i could test the Dv
Re: Golf 5 GTI 2009
Any other possible ideas?
- Voora Molester
Re: Golf 5 GTI 2009
Have the car scanned. Could be a few things, so a scan and error codes will put you on the right track
Re: Golf 5 GTI 2009
yup many possibilities.
Failed DV
Failed n75
leak
low fuel pressure.
scan is the place to start
Failed DV
Failed n75
leak
low fuel pressure.
Re: Golf 5 GTI 2009
Cool thanks gents ill check it out today
Re: Golf 5 GTI 2009
So inspected the DV all looks in order there?
- Belix
- Car Model: Passat B8
Re: Golf 5 GTI 2009
this really is your starting point...
Re: Golf 5 GTI 2009
So i got the following codes:P0444 system purge control circuit
P0033 turbocharger bypass valve contol circuit
P0243 turbocharger wastegate solenoid A
The state of all these are-no signal/communication.
Please help me out gents
Re: Golf 5 GTI 2009
change your DV.
Re: Golf 5 GTI 2009
Its got the latest piston type DV in
- dazza
- Car Make: VW and VW
- Membership No: 1327
Re: Golf 5 GTI 2009
Where are you based? Get the car to a dealer or a VW Indie to diagnose
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
Re: Golf 5 GTI 2009
Had a similar problem on my son's car.
Was a fuel pressure issue. Not sure exactly what.
Preshen from CPi(Ex I think) in Edenvale sorted it out.
Re: Golf 5 GTI 2009
this means the DV is not working. IE there is an electrical stuff up. so no matter that it is the latest type - either the plug is stuffed or a wire or the unit as it sees an electrical issue.
Re: Golf 5 GTI 2009
Gents problem is sorted, believe it or not it was a fuse causing all these problems
- Car Make: Audi,VW
- Car Model: A3 Sedan,Golf5 GTi BWA
Re: Golf 5 GTI 2009
What Fuse we talking about here?
I have a G5 Gti and many others, it will be good to know if I ever have a problem like this in future.
Re: Golf 5 GTI 2009
In the engine bay fuse panel, number F9 its a 10amp fuse its for engine management which controls the turbo wastegate solenoid and more
- Car Make: Audi,VW
Re: Golf 5 GTI 2009
Cool, thanks bud.
