I need to rewire the lift pump on a Mk2 gti.
Existing connector and wiring are brittle and broke off.
Where could I find a connector which fits on the pump?
Is there any specific type of wire which must be used?
looks like the one below.
Mk2 Lift pump wiring
- Abnormal
- Registered for: 20 years
- Membership No: 848
\Oo) \ _w_ / (oO/
- Abnormal
Re: Mk2 Lift pump wiring
Bump
Can I use any wire or are there fuel resistant types?
\Oo) \ _w_ / (oO/
not anything special as far as I am aware
- Car Model: MK3 Jetta 1.8 CSX, 1976 Beetle
Won't it possibly work if you just use the matching size spade plugs and cover neatly with silicone.
Not sure if silicone will hold up against the fuel, but maybe you can test it...
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
- Abnormal
Silicone wont survive.
Still would need some new wire though.
\Oo) \ _w_ / (oO/
fuel dissolves silicone. Do not put silicone sealer into a tank.
- Abnormal
ok cool. Will just use some spade clips and some wire then.
Yeah I am aware of that.panic-mechanic wrote: ↑Tue Sep 04, 2018 7:46 pm fuel dissolves silicone. Do not put silicone sealer into a tank.
\Oo) \ _w_ / (oO/
Sorry, my bad...panic-mechanic wrote: ↑Tue Sep 04, 2018 7:46 pm fuel dissolves silicone. Do not put silicone sealer into a tank.
Are the wires copper or aluminium?
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
