Hi Guys
I installed the 02J gearbox from the G4 Gti into my Caddy for the Turbo build. So while I'm busy with the wiring I thought about the calibration or ratio of this speed sensor. Are the speed sensors for 02J vs FFZ identical? In other words, will the speedo reflect the correct reading?
02J Gearbox speed sensor & Mk1 New spec cluster
- Boost
- Car Model: Caddy pickup
- Membership No: 1921
Current: 2008 VW Caddy R-Line 20V BIG T
2009 CW 9n3 Polo Gti
2012 Holden Captiva 2.2d LX
2011 Holden Cruze Equipe
2010 Great Wall V240 Ute
2017 Chev Captiva 2.2d LT daily
2000 Vw Citi 1.6i
2013 GW Audi A3 Sportback 1.8TFSI SE S-Tronic (POS)
2006 Volvo S40 T5
2004 Nissan 350Z Coupe
2000 VW Golf 4 GTI (247wKw @ 1.3bar)
2007 Fiat Grande Punto
1994 Fiat Uno Turbo
1994 Fiat Uno Pacer
2000 Vw Citi 1.6i
2006 Volvo S40 T5
1994 Fiat Uno Turbo
1994 Fiat Uno Pacer
Re: 02J Gearbox speed sensor & Mk1 New spec cluster
Did you check the size and gear tooth count on both? If gear tooth count match, they should be giving the same speed.
Some info from the forum for you.
https://www.vwclub.co.za/forum/viewtopic.php?t=162421
Just for info and reference, red gear with 15 teeth is used on my Caddy with Velocity dash and 020 gearbox.
020 speedometer cable gears:
020 3.9= 171 957 821 A (WHITE)
020 3.6= 171 957 821 B (RED)
020 4.2= 171 957 821 C (Green)
