good day
my citi golf 1.4i 2003 model is hunting when idling and has got a flat
spot when turning on corners... checked for codes and got p1050
I checked and cleaned map sensor and throttle...
still the same
help please.
citi golf 1.4 hunting when idling fault code P1050
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Re: citi golf 1.4 hunting when idling fault code P1050
How did you check the TB?
Sent from a phonebooth in Hillbrow
TB is throttle body.
