golf 1 not starting
Posted: Fri Aug 10, 2018 2:12 pm
Hi guys. ive got a golf 1 1.3 1989. Ever since I got it it gave troubles, usually I fix it my self but one issue I cant fix. in random moments the car just wont start. I turn the key, but nothing, no noise no crank not even a click. its not a dead battery, checked a thousand times. the only way to start is to connect a wire directly from the battery to the starter. Ive replaced the carb, the starting coil the ignition module. ive got new spark plugs with new distr cap and wires. ive checked the electronic chocked and everything is fine. I am stuck with this issue. Any help would be amazing
