Hi Gents
i need some assistance on my alarm/central locking system in my velociti.
im not able to open both front doors of the car
the driver side door unlocks with either the key or manually pulling the pin up however the door gets stuck in the latch and doesnt open completely
the passenger front door doesnt unlock at all and not able to pull up the pin manually or by key.
ive done the norm by removing the battery terminal and putting back on but still no luck the car starts and idles
any GURUS out there?
Velociti factory alarm
Re: Velociti factory alarm
Can you unlock and open the doors with the key lock when battery terminal is disconnected?
yes.... i had a relook at it again yesterday afternoon. it appears that the door locks are jammed and not the alarm
It sounds very likely that it can be the central locking unit, if one is fitted to your car as both front door locks will not fail at the same time.
If the door locks are jammed, open with keys and then remove the door locks and check for any broken parts in them or the linking to the central locking solenoids.
thanks for the feedback
i did come right and got the door open it turns out that the door lock itself was faulty so getting a new one soon
