03 Citi Golf stiff/hard gear changing.
- Gerpan ZA
Hi Guys,
I have been driving my citi golf 1.4i for a while now and have been curious about how normal this stiff/hard gear changing is.
When the car is stationary, hot, cold or driving the gear changing is hard. It is an arm workout. However I recently drove through a massive puddle of rain water in the road that thoroughly splashed the under carriage of my car and immediately afterwards when changing gears it was so unbelievably smooth and effortless but only for a minute or two.
I'm guessing the rain water lubricated something but what? A part is worn and needs replacing and lubrication?
Any help will be appreciated.
Sent from my SM-J530F using Tapatalk
Re: 03 Citi Golf stiff/hard gear changing.
yes look under the car and there is a bush that the shift arm runs in - start there. There are bush recon kits available from goldwagen
- Gerpan ZA
Hi Panic-Mechanic,
I will have a look at that, will have feedback as soon as I make progress.
Thanks for the help!
- Gerpan ZA
Worn out? Need lubrication? Both?
Impossible tomsay from that photo.. But follow the rod forward, there is a ball under the steering rack, that one is often worn and can be part of the problem.
You kind of need to take the links off and see where it becomes stiff. Section by section
- Car Make: ShitiGolf + CRX
My old man car has the same issue.
The little donut near the steering rack gets grotty and stiffens everything up.
climb under the car and Q20 each bush one at a time till you find the issue. Once you found who was the drama lama inspect for replacement.
- Gerpan ZA
Thanks guys, will use that method to troubleshoot!
I found on my Mk1 and my Fox that it's mostly the rubber ball that sits on the shift arm. I think that this is what Steve meant by "donut".
I do hope that the recon kits from GW have improved in quality. The one I used a few years ago didn't last very long. The bushes that mated the shift rods to the levers popped out or disintegrated. In the end, IIRC, I bought a kit from the agents.
- Gerpan ZA
Okay, I will have to take the quality into consideration aswell. The stiff gears really ruins the driving experience.VAG Fan wrote:I do hope that the recon kits from GW have improved in quality. The one I used a few years ago didn't last very long. The bushes that mated the shift rods to the levers popped out or disintegrated. In the end, IIRC, I bought a kit from the agents.
- Gerpan ZA
Hi Guys,
As you said, the problem was the ball/donut rubbers and links below the steering rack!
I cleaned that area, coated it thoroughly with Q20 and the gears was so smooth.
I am going to monitor the feel and if/when it gets stiff again I will replace.
