Hi all,
I'd appreciate some advice on a potential cause of the following problem..
My Citi Golf 2007 1.4i Velocity is cutting our when the revs drop sharply, as they do when gearing down. Starting is generally ok but probably not as quick as it should be and regular low rev idling is fine, as is driving.
Any ideas?
Engine cutting out
Re: Engine cutting out
you do not evengive nearly enough info or even what exactly the problem is or a very bad description of it.
- Sean Trollope
- Car Make: VW. Hyundai.
- Car Model: Citi golf. Hyundai i10
Based on that description check the piston return springs.
Please don't take this seriously.
