Lowering springs brand choice
- Car Model: Polo Vivo 1.6
Hi there guys, was hoping someone could help me on this matter. I am looking to drop my car with a lowering kit for the time being until i have the time to save for coil overs. now my question is the 40mm Evo lowering kit vs 40mm N-Force lowering kit.
Which is better between the two seeing as both are around the same price points
Car is a polo Vivo
Car is a polo Vivo
- Ian_F
- Registered for: 12 years
- Car Model: Voetswagen
- Membership No: 1846
Re: Lowering springs brand choice
Both aren't the best, but will suit your application.
- morribiscuit
- Car Model: Polo TDi SL
They will work. But SO often it comes back to “save the money, get Coilovers”.
A set of FK or Joms will set you back 5k-6k and then you will have the car sitting exactly how you want it. Want the front lower - you can do it. You will get the ride height you are after.
But back to your Q, on stock shocks a 40mm drop will be more than fine so take your pick.
Current: 1.9TDi SL | GTB17 , 7+7 billet | PD-Tuning Stage 3 - 180wkw, 512nm | FMIC, 57mm Straight Pipe | 'Akrapovic' tailpipes | JVC-KWV | FK coilovers | OZ Ultraleggera Reps | Vari Slotted Discs & EBC Green | K&N Cone Filter | HMS Custom Intake | When they ask what it cost, just say 'A bit'
- EX-DOHCTOR
- Membership No: 712
Eibach.
Im leaning more to the Side of the EVO mainly because they are green, seeing as it does not seem there is much difference between them but thanks to all for the advicemorribiscuit wrote: ↑Mon Jun 25, 2018 2:52 pm They will work. But SO often it comes back to “save the money, get Coilovers”.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Best advice is rather drive the car as is for now in stock setup and save up for the coilovers.
Patience is key.
Sent from my SM-A500F using Tapatalk
Patience is key.
- Car Model: Vivo GT
Anyone have pics of a vivo with jom coilies dropped to its lowest with stock rims.
2000 E46 325CI
1997 Toyota Corolla Rsi
2007 1.9TDi
2013 VW POLO VIVO GT
1995 E36 M3 German spec
1991 TOYOTA COROLLA 1.6GL
1990 BMW E30 325i CABRIOLET
1989 FIAT UNO TURBO
1979 FORD ESCORT 1600 SPORT
2007 1.9TDi
1989 FIAT UNO TURBO
- PoloRolo
- Car Model: Golf 7.5 R-Line
I would advise go for coilovers. Even a decent set of 2nd hand JOM coilovers.
But to answer your question, between the two brands I think there wouldn't be a noticeable difference between the two.
- ICE King
Depending on your mileage you might have to do shocks as the shocks might show fatigue after it is dropped with just springs.
Eventually new shocks and springs = Coil overs
- SuperVektr
- Car Model: Polo 6C GTi
I did some research as well and found that springs (Barons Cape Town: about R3.2k) with the koni sport shocks to be the best setup with that route, but would cost about R8k for everything incl fitment. FK coilies would end up costing less incl fitment, I got quoted for R1200 for fitment and wheel alignment, and FK coilies for about R5k-R6k.
You're on the right path; but, you have to choose for yourself.
I'm looking at getting coilies late next year because my warranty only ends in June 2020.
Edit: Got a re-quote from Barons Cape Town; still R2900 incl VAT
Rides
Current: Polo 6C GTi
Ex: 2017 Flash Red CitiVivo
Hi there guys, seeing as there was a fair amount of intrest on the post i am adding pics below of the install and some before and afters of the lowering spring install i did, i am pretty happy with how it turned out, the back could be lower but for the time i think it looks alot better than stock
overall i am pretty happy with the look ps. i am running 15s with 205/40/15
- Ian_F
Nice pics
- SuperVektr
Any update on how these held up after over a year?
Looking at getting springs for my Vivo, the Eibach are a bit pricey but have the perfect ride height for my application.
Just wanted to know how your experience with these were.
Rides
