Golf 1 hydraulic clutch pedal bracket
- saxo
Re: Golf 1 hydraulic clutch pedal bracket
Sell it as a complete kit with everything you need then here will be interest. Even I'll buy one.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
+1
Sent from a phonebooth in Hillbrow
I agree!
Hydraulic clutch in a Mk1 will make me buy one again for the wife.
1977 Datsun 1200GX
Wife's car: 2019 Suzuki Ciaz
1977 Datsun 1200GX
Put me on the list ..
Keen to see an explanation and full kit to get a whole picture of the kit. What is included and what needs to be purchased separate to complete the kit.
Would be awesome.
Would be awesome.
- Car Model: rox 20vt
Do you have a pic of how this bkt is mounted?
ONE STOP SPARES
For all your new and used vw parts
031 4652581
031 4652581
What he said
- Car Make: 2006 VW
- Car Model: 1.6i Velociti 2L
- Membership No: 2090
Also me...If you can put together a full kit ill definitely buy it
New 2019 G7 : For the comfort ekse
Current 2006 Velociti 1.6i2l: Back to my roots
EX 2013 Polo 1.6Tdi Sold
Ex 1992 Gti 2L 8v 288 Deceased
Ex 1991 Gti 2L 8v 272 Brothers now
Ex 2005 Velociti 1.6i Sold
Dear God. A one stop solution for the single greatest MK1 weekness is of massive interest.
Pics and pricing is a must.
Question? This for a 020 gearbox and deletes the clutch cable, correct?
Can also be adapted for use with 02* gearboxes, AKA cableshift gearbox?
I would think that 020 rod box will need a a piston cylinder attached to the arm on the gearbox. Has seen some pictures on vortex of a few.missioner wrote: ↑Fri Jun 22, 2018 1:07 pm Dear God. A one stop solution for the single greatest MK1 weekness is of massive interest.
Cable shift should be easier with this bracket and a slave cylinder that is piped to the cylinder on gearbox.
There is some 020 gearboxes fitted to I think Polo Vibo’s that has an integrated cylinder on the 5th gear casing. Same should apply as cable shift gearboxes.
- saxo
Do u perhaps have links to those threads on vortex?PapaJo wrote:I would think that 020 rod box will need a a piston cylinder attached to the arm on the gearbox. Has seen some pictures on vortex of a few.missioner wrote: ↑Fri Jun 22, 2018 1:07 pm Dear God. A one stop solution for the single greatest MK1 weekness is of massive interest.
Have lost the link, but here is one on this forum for some background. Work internet very weak and battle to search for it.Naku786 wrote: ↑Fri Jun 22, 2018 11:07 pmDo u perhaps have links to those threads on vortex?PapaJo wrote:I would think that 020 rod box will need a a piston cylinder attached to the arm on the gearbox. Has seen some pictures on vortex of a few.missioner wrote: ↑Fri Jun 22, 2018 1:07 pm Dear God. A one stop solution for the single greatest MK1 weekness is of massive interest.
https://vwclub.co.za/forum/viewtopic.php?t=158550
viewtopic.php?t=99312
retrofication.co.uk makes a similar kit and bracket to this one that the OP is showing and asking interested parties about. Comment placed as reference and not to derail the OP's post.
- saxo
You’re welcome.
- Car Make: ShitiGolf + CRX
Im in for the bracket with a master cylinder.
Pull type cylinders are available for beetle boxes, and will work for 020
now why did vw not think of this ??? great item
- Membership No: 1161
The car is built at a price
Sent from my Armor using Tapatalkvw block wrote:now why did vw not think of this ??? great item
- saxo
Hi all
I have been busy and waited for shipping, machining and so on.
This is how far I got, I will post an advert in the for sale section soon.
- Membership No: 2101
Howzit saxo
Any further update on these kits?
- Registered for: 4 years 9 months
Good Day, I am new to the forum and just want to esquire is there a full set with brackets available
What gearbox are you running?alettaj77@gmail.com wrote: ↑Tue Jul 16, 2019 7:43 pm Good Day, I am new to the forum and just want to esquire is there a full set with brackets available
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Saxo, is this for 020 Box? From the Pic you have on top it does look like, I just want to confirm that.
If so I will be very interested. Please can you PM me pricing.
Thank you.
Thank you.
Hi,, no my bracket is not for an 020 box unless you fit the golf 4 box that looks like the 020 boxes but it's hydraulic.
