Mk1 1.4 2007 carb water disappears
Hi there..
My mk1 1.4 carb gives me hard time with the coolant , first I've overall the engine and it was running smooth but after I've connected the heater it burst my wealsh pugs / wash plugs so I got them replaced no water leaks ... NOW when I run the engine everything seem fine until coolant overflow and come out from that hole in the bottle....I've bought and fitted the bottle and the cap but still it does the same ....what can I do :bang:
Thanks in advance
Thanks in advance
- Car Make: SEAT
Re: Mk1 1.4 2007 carb water disappears
Have you had the head tested?
And the radiator?
Replaced thermostat?
And the radiator?
This above and explain how the heater pipes were connected. Post pictures or describe piping routes. It could be the cause. Did motor run fine before you connected the heater pipes? I think your water line routes is not correct now, causing flow to be incorrect and not circulating and then motor overheats and water boils and push out on cap and little pipe.Supervan II wrote: ↑Sat Jun 16, 2018 9:41 am Have you had the head tested?
And the radiator?
Does the fans run?.
- Car Model: 1998 Polo Classic 1.8
How did you replace the welsh plugs? If you've used some kind of sealant you might have blocked off pipes causing overheating and over pressurizing.
1998 Polo Classic 1.8 with added "benefits"
yeah you are not going to block off a water port with a bit of sealant. The channel is pretty much huge behind there.
pratley steel will block off pipes if there is enough present.
- Sean Trollope
- Car Make: VW. Hyundai.
- Car Model: Citi golf. Hyundai i10
To me it sounds like there is a issue with how the pipes are connected(in the wrong places) also it generally takes a lot of force to burst a Welsh plug. So there is something seriously wrong.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
They rot with timeJuan the dealer wrote:To me it sounds like there is a issue with how the pipes are connected(in the wrong places) also it generally takes a lot of force to burst a Welsh plug. So there is something seriously wrong.
Sent from a phonebooth in Hillbrow
+1panic-mechanic wrote:Does the fans run?.
If yes could be faulty fan switch, always start cheap
- Sean Trollope
Could also be the lid on the water tank thing.
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Take the hose of your expansion tank while the car is running, if the water is trickling out instead of a solid stream, replace your waterpump internals
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
Check if both of your water pipes on your radiator are getting hot if the one is cold then your thermostat is faulty,also as panic said check if your radiator fan is working,also check the small water pipe on your water bottle if that is blocked your water also wont circulate and cause overheating.
