Solid (single mass) flywheel on AAL 16v motor
- Registered for: 6 years
Hi guys, which solid flywheel (210mm) will bolt up to a AAL 16 VALVE crankshaft? I appreciate your inputs.
Re: Solid (single mass) flywheel on AAL 16v motor
Which gearbox will be used?
The one from a cti. As a matter of fact all the 4cylinder engines of that era up to where they went to tfsi has the same bolt pattern.
Thanks Papajo and Panic mechanic. This motor (turbo I hope) will find it"s way into a Porsche 924. Will be using a 020 bellhousing(cut off from rest of gearbox) with concentric clutch and special made clutchplate to fit the spline count of the 924 torque tube.
