Hi, can anyone help with advice on what to check, it is as if the speedo is pluged out at the gearbox, speedo not working and feul gauge fluctuating, it used to work but I cleaned the engine and when I plugged out the speedo sensor to neaten up the wires I found the sensor pulling a apart in two pieces, I pushed it all back together and the speedo was working again for 2 days when it died, knowing there was a problem with the speedo sensor I replaced it but the speedo still wont work, any advice on where and how to test for what readings next and do anybody maybe know where I can find a wiring diagram for the newer round shape dashboard golf and caddy's please.
Thanks in advance
2004 Caddy speedo not working
- Armand
- Car Model: Black Magic 6R Polo Gti
- Membership No: 1828
2011 Black 6R Polo Gti (Forge intake, Viper dp, Stage 2 DNA sw)
2007 Polo gti (Giac software, 76mm dp, ITG Induction, custom FMIC)
2009 Citi 1.4i sport
1997 Uno turbo ( w/m, Tdo4 turbo, intercooler,76mm exhaust
Bmw 540i e34 (Standard)
Nissan 3.0 v6 (Brospeed branches and exhaust)
2009 Polo gti (Giac software)
Suzuki gsxr1000 k5 (Everything)
Vw caddy club (Mp9 conver, Branches, exhaust, chip)
Re: 2004 Caddy speedo not working
Is the gear proberly seated in the gearbox. I had the same problem where speedo wirked and stopped working. Found that gear popped up and not seated right down to the bottom in the casing. Refit and was working again.
You can fit a cordless drill to it and spin it in reverse to check if you get a speed reading.
- Armand
Hi, was this on a new shape dash with electronic speedo?PapaJo wrote: ↑Sat May 05, 2018 11:14 pm Is the gear proberly seated in the gearbox. I had the same problem where speedo wirked and stopped working. Found that gear popped up and not seated right down to the bottom in the casing. Refit and was working again.
Yes, I have installed new spec dash and wiring in my Caddy.Armand wrote: ↑Sat May 05, 2018 11:17 pmHi, was this on a new shape dash with electronic speedo?PapaJo wrote: ↑Sat May 05, 2018 11:14 pm Is the gear proberly seated in the gearbox. I had the same problem where speedo wirked and stopped working. Found that gear popped up and not seated right down to the bottom in the casing. Refit and was working again.
- Armand
Turned it with a drill but still dont work, tested the 3 points on the plug, got 12,3v, 10v in the middle and 3ohm on the 3rd to ground, any advise?
- Armand
I replaced the cluster and wasnt the fault aswell, checked all readings again, first wire was permanent 12v, second pin was the 10v signal and the last pin with brown wire was ground, I still got 3ohm between ground and the negative battery terminal, I started testing from the negative terminal to the engine and to the bolt just under the batter where al the other negatives connect to and found it has been making a bad connection there due to spray when the bakkie was sprayed and tested 2.4ohm between that point and the negative terminal, cleaned all the paint of between the terminals and tested again and got 0,04 ohm, tested between the negative terminal and the brown wire on the speedo sensing plug and got 0,4 ohms, tested and speedo was working fine
Well done!!Armand wrote: ↑Mon May 14, 2018 4:47 pm I replaced the cluster and wasnt the fault aswell, checked all readings again, first wire was permanent 12v, second pin was the 10v signal and the last pin with brown wire was ground, I still got 3ohm between ground and the negative battery terminal, I started testing from the negative terminal to the engine and to the bolt just under the batter where al the other negatives connect to and found it has been making a bad connection there due to spray when the bakkie was sprayed and tested 2.4ohm between that point and the negative terminal, cleaned all the paint of between the terminals and tested again and got 0,04 ohm, tested between the negative terminal and the brown wire on the speedo sensing plug and got 0,4 ohms, tested and speedo was working fine
