To retorque or not to retorque head bolts after 1000 kms.
Good day
I just want to find out if it is necessary to retorque head bolts after 1000 kms
and if it is needed what would the procedure be.
Some say to loosen the bolts a little and then retorque.
Thanks.....
Thanks.....
Re: To retorque or not to retorque head bolts after 1000 kms.
What motor?
But generally, no need to retorque. Torque them once and leave them.be.
- Registered for: 9 years 6 months
I haven't heard of head bolts that you have to retorque and they are normally TTY/stretch bolts and you can break them by tightening for a second time.
So if the workshop manual for your specific engine doesn't say you must retorque, then don't do it.
Rather replace the engine oil and filter after 1000km, after you worked inside the engine.
The cambelt broke so a rocker broke and bent 2 valves so we just replaced the rockerTerblanche wrote: ↑Fri May 04, 2018 2:37 am I haven't heard of head bolts that you have to retorque and they are normally TTY/stretch bolts and you can break them by tightening for a second time.
and done all the valves so no other work done besides the head.
- Rascal69
- Registered for: 16 years
- Car Model: MK1
- Membership No: 1490
If you followed the correct torque proceedure for that car then it should be ok... I remember doing a tazz with 4agze in november and for the head bolts it was something stupid like 40NM and then 90Degree and then another 90 degree and that was it... there was no requirement to retorque the head after 1000 km's..
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
- BIGMIG
- Porra Love
- Membership No: 1574
From what i have researched the old non stretch bolts needed to be re torqued, the reason for manufactures using stretch bolts was to do away with this old method so that customers didn't have to come back to the dealer for this mundane task plus some other various reasons.
Pot kak. You can't retoque torque to yield bolts. Go kick the oke in the nuts that told you that.
- BIGMIG
- Porra Love
Who are you referring too?panic-mechanic wrote: ↑Fri May 04, 2018 12:17 pm Pot kak. You can't retoque torque to yield bolts. Go kick the oke in the nuts that told you that.
The oke that told the OP to retorque a TTY bolt.
- ICE King
What do you retorque it to if it's was already done initially? Never understood this retorque business
I'd understand if the bolt came lose but then that would mean something wrong with bolt(thread or stretched) or it wasn't done properly initially
Sounds like a phrase used for the 1000km checkup after a major engine repair
Anyways , I would just buy new bolts if the current bolts has done alot of mileage or was used more than once
- BIGMIG
- Porra Love
Ahhh yes I see. I keep telling people not to reuse stretch bolts but if they are in a pinch then they can be reused but only once. More then twice is a definite toss them away.
- BIGMIG
- Porra Love
Re-torquing deals with the NON STRETCH bolt after it has gone through its thermal cycles and vibrations.
- ICE King
Use a steel gasket , new TTY bolts and you wont have to retorque
They used crappy head gaskets back in the day
it' not that. Cast iron heads with non stretch bolts would change clamping force after a few heat cycles. Since Aluminium heads and TTY bolts there is no such thing as re-torque. No matter what head gasket material is used.
Thanks for the advice and input guys I guess this topic can be put
to bed now,maybe it can be added to the frequently asked questions
section.
Cheers.
section.
Cheers.
