ABF Spluttering/ misfiring
Burn
Car Model: Caddy
Post by Burn » Sun Apr 08, 2018 7:09 am
Hi All
Need some help urgently on my mk1 ABF, Once vehicle reaches optimum temperature it starts to splutter or like reach a dead spot and then misfired back fires and is back to normal. 1st and 2nd can pull through rev range with no issue, problem comes in from 3rd after 3000rpm
I have changed fuel pump. Velo pump
Dizzy cap and rotor
All leads and Bosch coil
Fitted a new module ( Tp100 if I am not mistaken) last week and the problem has reduced substantially but is till present.
I also changer power and earth for the managment and redone vehicle earth.
Changed relay for fuel pump.
Car was tuned 2 weeks back at RBTS. Ross said it wasn't the map.
Any and all help will be highly appreciated
12 Polo Tsi
84 MK1 GT
04 Caddy
79 2 door
98 Caddy
04 Dot Com
Re: ABF Spluttering/ misfiring
Post by panic-mechanic » Sun Apr 08, 2018 3:09 pm
sounds like a tuning issue. Remeber things like water temp compensation and dwell time could cause what you are finding.
Also have you changed the plugs. You don't say.
Also try changing the plug gap - make it smaller.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
Burn
Car Model: Caddy
Post by Burn » Sun Apr 08, 2018 5:36 pm
Hi Stephan yes plugs were changed. Will try change gap, if that doesn't work I'll call u and see when we can arrange for a tune
12 Polo Tsi
84 MK1 GT
04 Caddy
79 2 door
98 Caddy
04 Dot Com
PapaJo
Post by PapaJo » Sun Apr 08, 2018 7:30 pm
How is the fuel pressure?
Burn
Car Model: Caddy
Post by Burn » Sun Apr 08, 2018 9:23 pm
No I did not test fuel pressure. Assumed it would be 100% since I put a new pump.
Should I add a Fuel pressure regulator ?
12 Polo Tsi
84 MK1 GT
04 Caddy
79 2 door
98 Caddy
04 Dot Com
Post by panic-mechanic » Tue Apr 10, 2018 10:13 am
There is already a fuel pressure regulator. He is suggesting that you just check it. Not saying you should add one. There could be other reasons why the pressure drops.
'09 Audi Q5 3l tdi
