Hi All,
I've search the site(trying to avoid repetition) and though some guys have similar problems, my exact problem wasn't noted, hence posting this. Apologies if this problem was already dealt with. So i'll be brief.
Car: Golf Mk3 GSX 1.8i (with air con - double fan)
Parts changed: Fuse 19 (30A) intact, Relay Fuse intact, Fan switch(November 2017)
Problem: Fan not working
Temp climbs during traffic, sits for a few minutes at the halfway(temp gauge) mark, but then climbs past and overheats. Once through traffic and driving freely, temp drops significantly to below halfway (probably the wind turning the fans).
My theory: Thermostat is probably working (hence the pause by halfway), but when the fans (low and high speed) should start working, it is not, so temp climbs beyond that point.
Question: its a 3 pin fan switch. if I bridge points, with the ignition on, should the fan go on? if it doesn't go on, does that mean I have a faulty fan switch?
Fan not working
- Krace
- Car Model: 2018 Polo TSI
Fan not working
Mazda 323 1.5L (OEM)
Uno Cento 1.1L 1997 (OEM)
Opel Corsa 1.4iL 1997 (OEM +)
Ford XR3 (OEM+)
Opel Astra 1.6i 1994 (OEM +)
Moto Mia Espresso 110
03' Peugoet 307 2.0 Turbo (OEM)
VW Polo Classic 1998 1.8i (OEM +)
98' VW Golf Mk3 1.8i GSX (OEM +)
02' Ford Focus 2.0 16V (OEM +)
94' Bantam 1600 (OEM)
02' Peugeot 206 GTI (OEM+)
2018 Polo TSI (OEM)
1997 Chico 1.3 (OEM)
Ford XR3 (OEM+)
2018 Polo TSI (OEM)
Re: Fan not working
If you bridge the points yes the fan should run. If they don't then the fan relay box or the fans themslves have given up the ghost.
It's usally relay box. Sits under the water expansion bottle on the left side of the engine bay.
- Krace
Re: Fan not working
Thank you Panic-Mechanic.
I'll replace the fan relay box then report back.
Called a few places now, not actually that easy to find. Will have to go in with a sample apparently (? pins).
Quoted R90 - R120.
Quoted R90 - R120.
Ford XR3 (OEM+)
2018 Polo TSI (OEM)
Ford XR3 (OEM+)
2018 Polo TSI (OEM)
Re: Fan not working
Oh that must be scrpayards? New from goldwagen about R800 odd.
- Krace
Re: Fan not working
Nope I called Suburban Spares and got a quote from them. If that's the price then they possibly quoted me on the wrong part.
Ford XR3 (OEM+)
2018 Polo TSI (OEM)
Ford XR3 (OEM+)
2018 Polo TSI (OEM)
