Hi guys,
Please could you help me.
My gf has a 2013 Mk6 TSI Comfortline and the headlight warning light/ "Check lights" meassge comes up every now and then. When I check, the fuse has burnt.
When this started, there were 20amp fuses in there. Changed them and all was fine for a while. I have also changed the globes.
Last week, it happened again and she took it to an auto electrician and he put in 2 10amp fuses. Yesterday I drove the car and saw that the indicators are now not working and one of the 10 amp fuses are burnt.
I searched online and found the following in regards to the correct fuse ratings.
What I need to know is, what are the correct fuse sizes to use on this car.
TIA
Fuses - MK6 TSI Comfortline
- YegsTC
- Car Model: Jetta CLX
1992 VW Jetta CLX Auto
ex:2002 Toyota Corolla - stock(modified driver)
Re: Fuses - MK6 TSI Comfortline
Does the fuse melt or is a clean pop. 20 amp is plenty so either there is a short in there or the incorrect wattage globes.
If the fuses are melted it means a bad contact somewhere so have a good look at the connectors to the globe.
for a 55 watt globe you only use 2.61 amp at 12 v. it is even lower at 13.8 v which most cars run when the engine is running.
here use this calculator in future
https://www.rapidtables.com/calc/electr ... lator.html
- Car Model: MK5 GTI DSG BWA
- Membership No: 1156
Have you checked the owners manual?
2012 Dec Mk6 GTI CW DSG - REVO Stage 1
Ex 2008 White Golf 5 Gti DSG REVO3 K04 - Weekend Toy
Regards
Hoosen
072 135 7861
Regards
Hoosen
072 135 7861
- Neuk
- Treasurer
- Membership No: 806
Hopefully they are better than before, VW/Audi owners manuals were notorious for being completely wrong when it came to fuse layout.Shygolf wrote:Have you checked the owners manual?
- YegsTC
Hi guys,
Used the above fuses. Seems to have rectified.
The 10 amp was a clean pop. Using H7 Hella bulbs.
