Good Day Everyone
Need advice on my Citi Golf 1.3 Chico 99"
I've recently done my motor over about 4 months ago. I've changed the water pump as well as oil pump when I did the overhaul. The problem I've got at the moment is that motor seems to be running very hot & quickly too. The water temperature gauge stays over the halfway mark & doesn't drop. I'm using Autozone 20w 50 Multi grade oil and for some reason when the weather is a bit colder than the low pressure warning light blinks...when it's warm weather the light doesn't come on. Just last week I bought a new radiator,thermostat & Antifreeze from Goldwagen.I flushed out the system before installing...still no luck, the temperature stays up past halfway mark. The good thing is the fan kicks in whenever the temperature gets too hot but my question is why is it getting so hot??? Help Please
Sent from my SM-J120F using Tapatalk
Motor & Water Temperature High
- vandyh
- Car Model: Velociti
Re: Motor & Water Temperature High
Did you check the small pipe from the bottle to the radiator? sometimes this one get clogged up.
Current ride
2007 - Jetta VI 2.0TDI
2007 - Velociti - 2.0 (91wkW, 174nm) @ 8V Performance
2014 - Kia Rio TEC
Previous rides
2008 - Polo 1.9 TDi 14i
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
2014 - Kia Rio TEC
Previous rides
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
