VOLKSWAGEN CITI GOLF CHICO LEFT BACKLIGHT NOT WORKING
WHY WOULD MY VOLKSWAGEN CITI GOLF CHICO'S LEFT BACK LIGHT ONLY WORK WHEN BRAKES ARE USED AND NOT IF LIGHTS IS TURNED ON? AND MY RIGHT BACK LIGHT IS WORKING WITH BOTH.
Re: VOLKSWAGEN CITI GOLF CHICO LEFT BACKLIGHT NOT WORKING
It has a dual filament globe.
Buy a new one and install it.
Cost R10 if you getting ripped off.
missioner wrote:It has a dual filament globe.
I did buy a new one and it still does that.
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
Also check that you've fitted the globe correctly.
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
Mk4 Jetta TDI - 79wKw, 256Nm atw @KAR
*Click here*
Margaret - '75 Audi 80 Restoration Project
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
+1Scatman wrote:Also check that you've fitted the globe correctly.
If you still having issues, it's likely that the earth for globe went missing. Check the globe holder for corrosion and also look at the connector, the last wire on one end is brown. That's the earth for the light cluster.
If you have a multimeter you can test for continuity from the globe connector to the body. If not, the earth point is under the carpet on the left side of the boot. Follow the wiring loom and you will find brown wires screwed to the body. Clean them with sand paper and tighten. Retest for earth. If the multimeter beeps you are winning.
Next step is to see if you have power to the globe. Get some one to help you while you use your same meter to test the circuits. Don't short out the globe socket with the probe it will blow fuses. If the power is there, the globe is faulty. If not, trace the conductor to the connector and check there. Still no power? It's one continuous wire from the light to the fuse box. Test the relevant fuse for continuity and then for power. If you got power replace the fuse, if not, replace the fuse box.
If this all sounds like seriously higher grade stuff, then go see an auto electrical shop and take vaseline. They won't give you any.
Good luck.
missioner wrote:+1Scatman wrote:Also check that you've fitted the globe correctly.
Good luck.
THANK YOU!! I WILL TRY IT. HOPE I WIN!!
- Scatman
- General
- Car Make: BMW
Did you win?MORNEB51 wrote:missioner wrote:+1Scatman wrote:Also check that you've fitted the globe correctly.
Good luck.
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
