HI All,
Seem to have an issue with CV joint bolts on my Citi Chico. The right inner CV bolts get loose. Had them changed a while back when it first happened a year ago but it seems to be acting up again. What will cause this to happen? I decided to start doing my own maintenance so would appreciate any advice on how to resolve this. What do I need to look for and what needs to be replaced?
Thanks in advance
CV Joint Bolts
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Re: CV Joint Bolts
They shouldn't loosen up by themselves ever, check that your right drive shaft isn't pulling away from the inner, you should have +- 10mm movement on the shaft when the car is on the ground, also looking at replacing the allen key bolts with the multi-spline ones, Goldwagen Delarey sell them as well as the 1/2" socket required for them.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
