Stretch tyres loosing air
- mk2fanatic
Hi guys, I have set of stretch tyres on a brand new set of rims however I have a problem with them loosing air regularly. Is this common ? Is there anything I can do to remedy the problem, this is really becoming quiet irritating, contemplating buying a new set of normal tyres if I can’t sort out the problem
- PoLonY
- Car Model: A8
- Membership No: 1997
Re: Stretch tyres loosing air
size of tyre and width of wheel? also what make of tyre?
You generally have to run a higher pressure in the tyre when running stretch to keep the sidewall seated but some tyres have stiffer sidewalls and others less so sometimes it's not needed.
Depends how much stretch as well.
Look and see where the leaks are, some tyre shops damage the bead when fitting tyres and creates small leaks.
Online
- Membership No: 2033
Answered your own question..... also what is "set of stretch tyres"? Specially made stretch tyres or just tyres incorrectly fitted?mk2fanatic wrote:Hi guys, I have set of stretch tyres on a brand new set of rims however I have a problem with them loosing air regularly. Is this common ? Is there anything I can do to remedy the problem, this is really becoming quiet irritating, contemplating buying a new set of normal tyres if I can’t sort out the problem
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- mk2fanatic
Heyy .. The tire size is 185-35-17 on a 7j rimPoLonY wrote:size of tyre and width of wheel? also what make of tyre?
When you say higher pressure, how much would be correct ?
- Wolfburger
- Registered for: 8 years
- Car Model: 6C Cross Polo
That shouldn't have leaked are u running a stepped wheel?
my current set up is a 185/35/17(Nangkang) on a 7.5j with no leaks at all
Current: 2015 6C Cross Polo TSI(Honey Orange) - Ginger
2009 Golf 5 GTI DSG - OEM Look - Sold
2007 Polo 9N3 Black Magic - Sold
1998 Bottle Green Jetta VR6 Executive - Sold
Admin to : https://www.facebook.com/pg/ScenePointsSa
- smashedmink
- Committee Member
- Registered for: 10 years 9 months
- Car Model: VW Fox
- Membership No: 1929
Definitely shouldn't leak unless pressure is already too low or wheel or tyre is damaged. I'm running 165/50r15 on a 7j, but pumped to 2.4 bar.
Current: 1991 VW Fox 1600L
Ex: 2003 Mk4 Golf GTi
132hp/98.5kw & 204nm atw @ Oettinger Edenvale
Ex: 1998 Mk3 Jetta CLi 2.0
116.6hp/87kw & 179nm atw @ Stealth (Coastal + NF 5ron)
- Neuk
- Treasurer
- Membership No: 806
I've never had issues with my 'stretched' tyres but they aren't that stretched in my opinion and I always run higher pressures in them.
- Wolf Mk2 16V
Crazy! Form over function gone mad
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
- smitbrandon
I ran my 205/40/17 on a 8.25j on 2.6bar front and 2.4bar back. Never had any issuesmk2fanatic wrote:Heyy .. The tire size is 185-35-17 on a 7j rimPoLonY wrote:size of tyre and width of wheel? also what make of tyre?
- hostility
- ↰ ↓ 4 ?
- Car Make: Anaconda
- Car Model: 22"
- Membership No: 1624
Damaged bead when fitting more than likely. Had a few cases of this myself. Strip tyres and inspect inner bead wall......If not then tyre sealant and up the bar a bit.
Current :
Honda Prelude 2.2Vtec Revive - Project StarScream
Exes :
Apocalypse - Bagged Twincharged MK6 Jetta SOLD
The Hostile One - Bagged & K04 - 226kw 420nm SOLD
My Vivo SOLD
My Corsa - 252wkw/370nm SOLD
Exes :
My Vivo SOLD
