Golf MK1 rev counter
Keeganp
Registered for: 8 years
Post by Keeganp »
Please can you assist I changed my carb engine to MP9 injection.My rev counter does not work.sqaure dash 1987
Im using a square 3 pin coil.
Thanks,
PapaJo
Registered for: 14 years
Car Make: VW's
Re: Golf MK1 rev counter
Post by PapaJo »
Let me get this right, you have mp9 installed and still the square dash. You will need to find the mp9 tacho wire from ecu to mp9 rev counter and then wire in a tp100. (12v, earth, input from mp9 wire that was supposed to go to mp9 rev counter to pin 6 on the tp100 and then pin 7 on the tp100 to the square dash rev counter.
Does your distributor have a single or 4 window trigger in distributor.
Keeganp
Post by Keeganp »
It’s has 4 window
PapaJo
Car Make: VW's
Post by PapaJo »
Keeganp wrote:It’s has 4 window
Fine.
1987 will use a coil negative rev counter. it would have had a red with black trace that went onto the round coil. On the 3 pin coil now open the plastic cover above the plug. On the righthand bolt connect the red/black wire.
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
panic-mechanic wrote:1987 will use a coil negative rev counter. it would have had a red with black trace that went onto the round coil. On the 3 pin coil now open the plastic cover above the plug. On the righthand bolt connect the red/black wire.
Handy to know this.
PapaJo
Car Make: VW's
Post by PapaJo »
Handy to know this.
Thanks, Panic. That is a much easier solution than mine.
UDC
Membership No: 1041
Post by UDC »
on my mkII I had to solder a wire with a spade connector directly to that right hand side pin as there was no bolt connector, rev counter works fine from there for the old dash/rev counter models.
