Dead Aircon
Pik Sooter
Registered for: 11 years
Car Model: MK2 Q5 3.0T l MK2 TT Roadster
Membership No: 1893
Dead Aircon
Post by Pik Sooter »
Hi guys.
So after my turbo replacement, I have been having a funny issue with my aircon. It worked for a month after the turbo replacement was done, then winter rolled around, so didn't really need it. Anyhoe, summer comes rolling, aircon works for a week, and then dead.
So I thought maybe the gas was finished or it got a leak. Went to a aircon guy, asked him to check if the Evap system holds vacuum, as if it doesn't, means a leak is present.
Anyway, he plugs his refil system in, I switch on the car and put the aircon on full blast, the pump doesn't turn on.
So we check all internal fuses, no issues, check the plug, no power to the plug. We then checked the ground wire from aircon plug, has voltage. So he runs a wire from the positive terminal on the battery to the pump, it immediatly kicks on and starts pulling vacuum, faulty pump ruled out.
So I quickly scan the car, non critical fault: Climate Control Fault. I don't have climate control, just the manual knobs thingy. Could this be faulty?
Sent from my LG-H955 using Tapatalk
chucker02
Car Model: Citi ADY
Re: Dead Aircon
Post by chucker02 »
Check the A/C pressure sensor. Will sit somewhere on one of the pipes. It usually has 2 wires to it. Put the aircon on with the car idling and use a jumper wire between the 2 pins on the plugs and see if the pump comes on
1971 VW beetle
Pik Sooter
Membership No: 1893
Re: Dead Aircon
chucker02 wrote:Check the A/C pressure sensor. Will sit somewhere on one of the pipes. It usually has 2 wires to it. Put the aircon on with the car idling and use a jumper wire between the 2 pins on the plugs and see if the pump comes on
Thanks Chucker, will give it a shot in the morning. Would really hate to have to replace that whole control panel, can only imagine what it will cost. If your trick works, does it mean the sensor is faulty and has to be replaced.
chucker02
Car Model: Citi ADY
Re: Dead Aircon
Post by chucker02 »
No problem bud, yes if that works replace the sensor
1971 VW beetle
Re: Dead Aircon
you should be able to see in the reading blocks on HVAC what the pump status is ie if the system has decided to switch it on or not.
Will also show the system gas pressure and if it is happy with that. This will guide you to whether it is a switch issue or maybe a relay / fuse or something that does not give the signal to the pump.
Does the internal fan run. if not it won't kick the aircon compressor on.
