Recommended mag size for a polo 1.2 tsi trendline
Hi guys, I want to biy mag wheels for my car and I'm thinking about going for 17" rims. I like the new polo gti rims or the older one but I don't know if it a good idea to buy replica. As for the correct mag size/pcd I'm also not sure. Please help.
Sent from my VTR-L09 using Tapatalk
- Neuk
- Treasurer
- Membership No: 806
Re: Recommended mag size for a polo 1.2 tsi trendline
What is standard on your car? Take those details, find an online converted and go from there. PCD should be 5x100 and I prefer not going for fake wheels, or replica's as many are simply fake and of poor quality.
- Car Make: SEAT
Larger rims require wider tyres.
Petrol consumption suffers.
Tyres become more expensive (in most cases)
I'd recommend looking at 17" only if your current vehicle has 16". One size up is the general rule of thumb.
Check the price for your current tyre size first, then compare it with the size you think will suit your pocket.
Take particular note of the offset (ET) of your current rim and avoid extreme variances.
Oh, and OEM rims can be quite expensive, unless buying used.
My R0.02 worth.
My R0.02 worth.
- smitbrandon
What style are you ultimately looking at? Are you in the long term going to go stance mode or do you want to stick to stock look with a nice rim for a daily driver?
If you are thinking of dropping the car in the back of your mind I would suggest going with 16s with a 40 sidewall and 195 up to a 215 max width.
These tsi have small spacings for wide rims.
If you aren't going to do the drop setup then I'd say go 17s with a 40 sidewall and a 215 or 225 width. That should look decent and it will be ideal for a daily.
Ciao
Ciao
- Wolfburger
- Registered for: 8 years
- Car Model: 6C Cross Polo
Got a set 17 inch oem Audi Phat 5 in a high polished finish if interested
Never been fitted immaculate condition pm me if u interested
Current: 2015 6C Cross Polo TSI(Honey Orange) - Ginger
2009 Golf 5 GTI DSG - OEM Look - Sold
2007 Polo 9N3 Black Magic - Sold
1998 Bottle Green Jetta VR6 Executive - Sold
Admin to : https://www.facebook.com/pg/ScenePointsSa
- Wolfburger
Audi Phat 5 wheels 17 inch 5x100
My car with 205/40/17
Sent from my HUAWEI RIO-L01 using Tapatalk
- Neuk
- Treasurer
OP, please don't do any of this until you have done a comparison to the stock, firstly to check clearances and secondly to ensure that you don't affect the rolling circumference of the wheel so much that it puts your speedometer, odometer and trip meter out.smitbrandon wrote:What style are you ultimately looking at? Are you in the long term going to go stance mode or do you want to stick to stock look with a nice rim for a daily driver?
Ciao
They say with the mag size, you can go 1 or 2 size up and considering that a trendline, comfortline and a highline is basically the same car, with a highline coming out with 16/17", do you think putting 17" on a trendline will be a problem?Neuk wrote:OP, please don't do any of this until you have done a comparison to the stock, firstly to check clearances and secondly to ensure that you don't affect the rolling circumference of the wheel so much that it puts your speedometer, odometer and trip meter out.smitbrandon wrote:What style are you ultimately looking at? Are you in the long term going to go stance mode or do you want to stick to stock look with a nice rim for a daily driver?
Ciao
Looking good hey.. Thanks bruDIKKIES wrote:My car with 205/40/17
I'm just looking for a nice vw mag/rim for everyday drive. I would have gone with a second hand 16" vw polo tsi rims but when I went to the tyre shop, they told me that 16" tyres are expensive.smitbrandon wrote:What style are you ultimately looking at? Are you in the long term going to go stance mode or do you want to stick to stock look with a nice rim for a daily driver?
Ciao
Hi, thanks for your reply. Isn't a trendline and a comfortline/highline a same car? I'm asking because a comfortline comes with 16" and highline with 17".Supervan II wrote:Larger rims require wider tyres.
My R0.02 worth.
And the original is very very expensive. I went to vw the other day and asked how much is a set, I think I asked for 16/17" tsi rims. They said it's about R17 000 without tyres.Neuk wrote:What is standard on your car? Take those details, find an online converted and go from there. PCD should be 5x100 and I prefer not going for fake wheels, or replica's as many are simply fake and of poor quality.
- Neuk
- Treasurer
There won't be a problem as long as you properly compare the new setup to the old setup to make sure you have no clearance issues and don't affect the rolling circumference too much. It may not be the best idea to go for heavy wheels though, with such a small engine.Teeh17 wrote:They say with the mag size, you can go 1 or 2 size up and considering that a trendline, comfortline and a highline is basically the same car, with a highline coming out with 16/17", do you think putting 17" on a trendline will be a problem?Neuk wrote:OP, please don't do any of this until you have done a comparison to the stock, firstly to check clearances and secondly to ensure that you don't affect the rolling circumference of the wheel so much that it puts your speedometer, odometer and trip meter out.smitbrandon wrote:What style are you ultimately looking at? Are you in the long term going to go stance mode or do you want to stick to stock look with a nice rim for a daily driver?
Ciao
To be honest, I wanted 16" tsi 5 spoke original rims, I was going to buy used ones but they told me about the tyre price. What would you suggest?Neuk wrote:There won't be a problem as long as you properly compare the new setup to the old setup to make sure you have no clearance issues and don't affect the rolling circumference too much. It may not be the best idea to go for heavy wheels though, with such a small engine.Teeh17 wrote:They say with the mag size, you can go 1 or 2 size up and considering that a trendline, comfortline and a highline is basically the same car, with a highline coming out with 16/17", do you think putting 17" on a trendline will be a problem?Neuk wrote:OP, please don't do any of this until you have done a comparison to the stock, firstly to check clearances and secondly to ensure that you don't affect the rolling circumference of the wheel so much that it puts your speedometer, odometer and trip meter out.smitbrandon wrote:What style are you ultimately looking at? Are you in the long term going to go stance mode or do you want to stick to stock look with a nice rim for a daily driver?
Ciao
- Neuk
- Treasurer
What is the difference in tyre price?Teeh17 wrote:To be honest, I wanted 16" tsi 5 spoke original rims, I was going to buy used ones but they told me about the tyre price. What would you suggest?
Right now I'm looking at a 215/40/16 continental = R2, 141 each tyreNeuk wrote:What is the difference in tyre price?Teeh17 wrote:To be honest, I wanted 16" tsi 5 spoke original rims, I was going to buy used ones but they told me about the tyre price. What would you suggest?
And 215/40/17 start from R1, 300(GT radial), R1, 700 for YokohamaTeeh17 wrote:Right now I'm looking at a 215/40/16 continental = R2, 141 each tyreNeuk wrote:What is the difference in tyre price?Teeh17 wrote:To be honest, I wanted 16" tsi 5 spoke original rims, I was going to buy used ones but they told me about the tyre price. What would you suggest?
- Neuk
- Treasurer
That's not a huge difference, what about other brands like Toyo or Hankook?Teeh17 wrote:And 215/40/17 start from R1, 300(GT radial), R1, 700 for YokohamaTeeh17 wrote:Right now I'm looking at a 215/40/16 continental = R2, 141 each tyreNeuk wrote:What is the difference in tyre price?Teeh17 wrote:To be honest, I wanted 16" tsi 5 spoke original rims, I was going to buy used ones but they told me about the tyre price. What would you suggest?
Hankook 215/45 R16 = R1, 500 on special and the rest of the brands are R2, 000 or more.Neuk wrote:That's not a huge difference, what about other brands like Toyo or Hankook?Teeh17 wrote:And 215/40/17 start from R1, 300(GT radial), R1, 700 for YokohamaTeeh17 wrote:Right now I'm looking at a 215/40/16 continental = R2, 141 each tyreNeuk wrote:
But I'm going the tyre shop to make proper quotes today and i will update you.Teeh17 wrote:Hankook 215/45 R16 = R1, 500 on special and the rest of the brands are R2, 000 or more.Neuk wrote:That's not a huge difference, what about other brands like Toyo or Hankook?Teeh17 wrote:And 215/40/17 start from R1, 300(GT radial), R1, 700 for YokohamaTeeh17 wrote:Right now I'm looking at a 215/40/16 continental = R2, 141 each tyre
- Neuk
- Treasurer
What is your current tyre size?Teeh17 wrote:But I'm going the tyre shop to make proper quotes today and i will update you.Teeh17 wrote:Hankook 215/45 R16 = R1, 500 on special and the rest of the brands are R2, 000 or more.Neuk wrote:That's not a huge difference, what about other brands like Toyo or Hankook?Teeh17 wrote:And 215/40/17 start from R1, 300(GT radial), R1, 700 for Yokohama
175/70 R14Neuk wrote:What is your current tyre size?Teeh17 wrote:But I'm going the tyre shop to make proper quotes today and i will update you.Teeh17 wrote:Hankook 215/45 R16 = R1, 500 on special and the rest of the brands are R2, 000 or more.Neuk wrote:
- Neuk
- Treasurer
175/70 R14 to 215/45 R16 - 0% change in circumference so no change in speedometer, odometer or tripmeter.
175/70 R14 to 215/40 R17 - 0.8% change in circumference so small change in speedometer, odometer and tripmeter.
175/70 R14 to 205/40 R17 - -0.4% change in circumference so small change in speedometer, odometer and tripmeter.
- Car Make: SEAT
If they all have the same engine size then you already have the specs/examples to work with - if you are looking at the same rim, of course.Teeh17 wrote:Hi, thanks for your reply. Isn't a trendline and a comfortline/highline a same car? I'm asking because a comfortline comes with 16" and highline with 17".
Different rim usually means different specs, eg >< offset, so be aware.
