Hi all,
So theres been a kak sound coming from the front wheels for a few days and this morning I had some time to look. To my horror, i found that 2 of the 6 bolts holding the inner CV on driver's side has sheared off Not sure how this happens!? But the screew part is still inside CV body. Furthermore, i found that the remaining 4 were loose!! Now how the flying **** does this happen i'd love to know, but more importantly, where does one find these in order to replace. I managed to tighten remaining 4 bolts as best i could.
TIA
Inner CV joint bolts
- Registered for: 11 years
- Car Make: Chevy
- Car Model: Sonic 1.6 LS B&W
- Car Make: Chevy
Re: Inner CV joint bolts
Sorry this is for citi golf
- Car Model: Citi 1.8i Ltd
- Membership No: 1972
goldwagen can help you with new bolts.
- Car Model: MK5 GTI DSG BWA
- Membership No: 1156
Goldwagen or any bolt & nut place will sell these. Ask for Tensile bolts.
also use Loctite.
From past experience, this happened whenever I reused the bolts.
also use Loctite.
2012 Dec Mk6 GTI CW DSG - REVO Stage 1
Ex 2008 White Golf 5 Gti DSG REVO3 K04 - Weekend Toy
Regards
Hoosen
072 135 7861
Regards
Hoosen
072 135 7861
- Car Make: Chevy
I see, ok makes sense. thanks for the info. Also, any ideas how to get the remainder of the screws out?
- dcmk4
- Car Model: MK7 GTi
Are the spreader plate things still on the CVs?
if you undo the rest and pull the cv away the broken bits should simply unscrew by hand or pliers
