I need help guys...i have a 97 polo classic 1.6i. The problem is my headlights are very dim
I've read up on relay install on the forum..but I have two sets of wires for each headlight..i want to know if I can split the wires from the relay the high beam and same for low beam...i have two sets of wires for each headlight....i want to take the two high/low beam wires and join them togher to each relay and split them from each relay to the 2 headlights...any help is much appreciated
Re: I need help guys...i have a 97 polo classic 1.6i. The problem is my headlights are very dim
so there is a high beam and low beam to each light. basically to make it easier pick the side that is closest to the battery to install the relay.
Cut both hea and both low beams. On the side where the relay will not sit insulate the side that comes form the loom and extend the side to the light to reach the relay. Yes join the two high beam wires and install that on the one relay. Put the wire form the loom as the signal on the relay.
Same for dim.
Remember to put a fuse between the battery and the relay on the supply side.
Same for dim.
- Car Make: vw ,audi
- Car Model: mk1 & Audi A3
Give the guys at violet electronics a call. The sell HD kits that will sort out your dull yellow lights. I have personally installed a kits on all my cars and have sold to my mates. No problems at all. Its plug and play. You can even choose how bright the lights must shine. Give me a call i will gladly give u a demo.......my contact details .....zero6zero5717216.....Shaun
And they scatter light everywhere and annoy the living hell out of anybody coming from the front.
HID is focussed differently and is meant to go into projectors designed for it with proper cutoff shutters and self levelling systems so as not to blind oncoming traffic. None of these kits do that and is actually illegal but not that anybody cares about that in SA.
Don't be that guy that blind everybody so that all the oncoming traffic hits you with brights all the time.
+100000panic-mechanic wrote:And they scatter light everywhere and annoy the living hell out of anybody coming from the front.
The guys on the road with after market headlights are very annoying.
+ another 100000madracer21 wrote:+100000panic-mechanic wrote:And they scatter light everywhere and annoy the living hell out of anybody coming from the front.
When I see one of those, I quite willingly and ruthlessly switch to brights.
I seriously get the urge to pull them over. beat the hell out of them and shove the headlight into their rectum.VAG Fan wrote:When I see one of those, I quite willingly and ruthlessly switch to brights.
Then they go past and I calm down after a moment or two
