Hi guys,me again..My x-flow build that i did is still going strong I now want to take my 1.8 and do the 2.0 shortblock.From what i have seen i will need the 2.6 caravelle pistons(82.5mm) and a 2.0 crank.I just want to know if the crank from the newer 2.0 8v vw engines will work if i remove the drive gear for the oilpump?
APK/AZJ 2.0 crank for shortblock build.
Re: APK/AZJ 2.0 crank for shortblock build.
Also,what is the max bore size for a dx block?
Crank needs to have the gear removed and needs machining shorter and the nose changes.
Dx is just like any of those blocks. Some guys say 84.5 but I personally am not comfortable with that.
Thanks again panic,you are my hero i will rather sell the crank then and buy ady/2E crank.Think i will just stick to 82.5mm pistons to be on the safe side.
- WeirdSteam
- Car Model: A3 Sportback 1.8 TFSI
Yup I recently built my 2.0 shortblock
Have 83.5mm caravelle Pistons in mine (AFV Block) wont go bigger than 83.5mm the walls start to get thin.
this is with 83.5mm pistons
Up to 83.5 i am ok. Aftert that even the are between the cylinders for the gasket to seal get dubious.
- vandyh
- Car Model: Velociti
Hi,
Is your build finished yet?
I am curios to see whats the gains between 82.5 & 83.5mm will be.
Current ride
2007 - Jetta VI 2.0TDI
2007 - Velociti - 2.0 (91wkW, 174nm) @ 8V Performance
2014 - Kia Rio TEC
Previous rides
2008 - Polo 1.9 TDi 14i
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
2014 - Kia Rio TEC
Previous rides
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
Hi,no build has been put on hold for now..but as soon as it fires up again i will start a thread on the buildvandyh wrote:Hi,
