Hi Guys,
A friend of mine is having a weird issue with his velo cluster.
The cluster reads normal at idle however, when he revs the car, the cluster rpm gauge would not move.
He bought the car as a shell and transplanted a 16v setup in there with Dictator Standard however, upon thinking the cluster is the issue, he swopped out working clusters from other cars and the issue is the same.
I am not to technically clued up in terms of wiring etc. but if you guys could provide some input and i will relay the message to him.
Thanks in advance.
Assistance with Velociti Cluster
- Car Model: Cti
- Membership No: 2095
Re: Assistance with Velociti Cluster
Getting some think around on the problem. This is a 16V motor with Dicktator standard and upon normal idle the RPM gauge on cluster reads correct. Clarify if wiring for the 16v is from a 4 window 16V distributor seeing that he is using Dicktator standard. Give some back ground how the wiring is done on the ignition trigger and wiring to and from cluster, coil type and its wiring.
Suppose car is driving and only having a problem with the cluster as from your post derived. This could possibly be a wiring mismatch. Where is the earth wires connected to and does he have the motor earth connected? I think the earthing is open (not connected at the correct point) and drawing current through other components causing this.
and modernish citi had that boarnetz setup. i know nothing about it and basically usually leave the stock management there to take care of that.
But if no boardnetz if might just need a little more voltage. Have often come right by simply adding a 2k2 resistor to 12v to the rpm line and voila.
- Car Model: Cti
Hi Guys,
Thanks for the replies, he managed to get an auto electrician to have a look at it yesterday, one of the wires had been broken off, fixed this up and problem solved.
Sorry I did not give much info in terms of how it was wired as I am completely unsure about that. Thanks for the replies though. Much appreciated.
Tashveer wrote:Hi Guys,
