Polo 2004 BLM 1.4i 9n coil pack firing
Siya G
Registered for: 6 years 7 months
Car Model: mk3
Post by Siya G »
Morning guys,
My car has recently overheated,I have got the head skimmed and values tested, replaced the cam belt and plug lead cables. However the car makes a spluttering noise when started up, i want to off by making sure I have correctly done the lead cables to the coil pack.
I've tried to Google but haven't had much luck finding a post that relates to the model of mine mentioned in the topic.
I am looking for the firing order for Polo 2004 BLM 1.4i 9n
Re: Polo 2004 BLM 1.4i 9n coil pack firing
1342. But firing order measn very litle on a wasted spark motor. You need the correct pairs togehter on the right side.
So 1,4 has ro be paired and 2,3 has to be paired.
1,4 paired on coil A and 2,3 paired on coil B.
if the coil pack is marked ABCD then
a=1
b=4
c=2
d=4
Siya G
Car Model: mk3
Post by Siya G »
Thanks! I will do it and let you know!
