What aftermarket Coolant Monitor, coolant level and Temp?
- ThatBloke
Some vehicles have better factory coolant monitoring systems but the fact remains that catastrophic/rapid coolant loss equals catastrophic engine failure, by the time you notice something is wrong it's too late and then the full rebuild starts, with newer engines that can easily go well past R50k, some even north of R100k. It's so dire that some factory temp sensors only work when there's coolant covering them, no coolant equals temp sensor doesn't even pick up the overheating
What aftermarket coolant monitoring systems are available, something that warns you on low coolant level and/or high engine temps?
Re: What aftermarket Coolant Monitor, coolant level and Temp?
That is a really good question, would like to get some answers on this to.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Online
- Membership No: 2033
There is always the MadMan that guys use on Defenders and other Landies
https://www.madman.co.za/index.php
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- ThatBloke
Looks good, on sedans/most passenger vehicles you'd have to use the DIY kit:Howie-WP wrote:There is always the MadMan that guys use on Defenders and other Landies
https://www.madman.co.za/index.php/wher ... ry/diy-kit
Around R4k for a setup
The madman display unit is a bit of an overkill for most purposes, it can do a lot of other monitoring if you buy all the extra sender units.
There must be other options on the market apart from Madman?
Online
There was a Little Black Box, which gave audible (and light) alarms for water temp and water loss.
http://www.littleblackbox.co.za/
Checked these out for my Defender. Ended up buying the VW expansion bottle and will hook up to simple light.
HOWIE-WP,
I think Auto-watch has a system where they screw an additional sensor into the radiator top tank. which is linked to the immobiliser which then cut ignition current if the sensor detect water loss. Speak to Anton Meyer at Motion Fitment Centre they have installed many of these on military vehicles.
011 894 3635.
011 894 3635.
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Don't see why the low coolant level would be something you wouldn't physically see?ThatBloke wrote:Some vehicles have better factory coolant monitoring systems but the fact remains that catastrophic/rapid coolant loss equals catastrophic engine failure, by the time you notice something is wrong it's too late and then the full rebuild starts, with newer engines that can easily go well past R50k, some even north of R100k. It's so dire that some factory temp sensors only work when there's coolant covering them, no coolant equals temp sensor doesn't even pick up the overheating
surely puddle on the floor is the first sign, get a glowshift temp gauge from FSU Developments some of them have an audible alarm and a light when the temp is too high, you preset it to whatever temperature you want.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- ThatBloke
Suppose you might spot a leak if you drive with the windows wide open, your head stuck out and scanning the bottom of car for leaks, might be a bit of a challenge at 120km/hr freeway driving but each to his own..AlexTDi wrote:Don't see why the low coolant level would be something you wouldn't physically see?ThatBloke wrote:Some vehicles have better factory coolant monitoring systems but the fact remains that catastrophic/rapid coolant loss equals catastrophic engine failure, by the time you notice something is wrong it's too late and then the full rebuild starts, with newer engines that can easily go well past R50k, some even north of R100k. It's so dire that some factory temp sensors only work when there's coolant covering them, no coolant equals temp sensor doesn't even pick up the overheating
Sometimes cooling systems pop a serious leak randomly whilst on the move, certain vehicles Audi and BMW apparently have a tendency to do this, also road debris thrown into the radiator can do a similar thing on any vehicle. So the coolant dumps in a minute or 2 and bobs your daughter engine cooked. You may be fortunate enough to somehow notice it early but more often than not it's only when the engine starts seizing that you get an idea of something amiss.
Probably not the biggest issue on a 1.4l cheapie but as the engine gets bigger and more complex an engine write off out of warranty becomes quite a serious affair, never mind the hassle during and after the rebuild.
What car do you drive? . Vw includes both since very early year cars. Asa matter of fact coolant level since 1980.
But look at MGL avionics. There is something called an engine monitor.
Madman takes that and repurposes or makes up plug and play harnesses using that as the base and then charge people a living fortune.
Thy are a local company based in stellenbosh
Www.mglavionics.co.za
- ThatBloke
Thanks panic, just the info I'm looking for.
Haven't got the vehicle yet but thinking of getting 6 cylinder Audi or BMW and those are not the engines you want to overheat.
- NHB_R
P3 gauge?
Awron Gauge?
Awron Gauge?
@OP u are correct, bmw loves to blow those water flanges around and under the intake manifold. Changed tons of those.
- ThatBloke
Panic if you have a chance could you please have a look on that site and direct me to the units you are referring to?panic-mechanic wrote:What car do you drive? . Vw includes both since very early year cars. Asa matter of fact coolant level since 1980.
http://Www.mglavionics.co.za
I had a look and I can't see anything that looks like the Madman base unit.
Only page that looks close is called RDAC engine monitors but those units look like they interface with an existing display:
http://www.mglavionics.co.za/RDAC.htm
- ThatBloke
Those are some classy monitoring systems but the prices are pretty insane, that's US street prices, hate to know the SA street price.NHB_R wrote:P3 gauge?
Awron Gauge?
I want cheapest possible DIY solution that's sound, Panics option looks promising.
E-3 here
http://www.mglavionics.co.za/infinity.html
Ems here
Ems here
- ThatBloke
Thanks Panic, will those guys sell to the public or do you need to order via a retailer?
order straight from them and they mail.
- ThatBloke
Panic, sorry to be a pita but I'm in front of the PC now and I can't find the E3 or EMS at either of those links?panic-mechanic wrote:E-3 here
Ems here
Edit, found the E-3, EMS still mia!
- ThatBloke
Found the E-3 at another site for R2k incl vate:
http://cometaviationsupplies.co.za/inde ... ct_id=3703
- Chuck_Norris
- Car Model: Polo 1.9 TDI
It is on the site infinity - I3 Infiniteq Smart Single – E3 Price R2089
http://www.mglavionics.co.za/Infinitec/ ... y.html#IE3
Price List
http://www.mglavionics.co.za/pricelistzar.pdf
Datasheet :
http://www.mglavionics.co.za/Infinitec/Manuals/E3.pdf
Price List
Datasheet :
Ex - 1.9tdi Highline
http://vwclub.co.za/forum/viewtopic.php?f=11&t=161270
Current - Tiguan 2.0T - 4 Motion
http://vwclub.co.za/forum/viewtopic.php?f=11&t=183069
