Hi guys,
need some help, i'm getting an annoying squeak from the engine bay area on my IC 1.8T, I have replaced both engine and gearbox mounts (worn). changed the DP gasket and the turbo gasket but the sound persists. It occurs when changing gears or when going over bumps on the road. It sounds like metal on metal. I have a feeling it is the DP but i have checked all the bolts, they are secure. any ideas as to what could be the issue?
Regards
Chris
Squeak from engine bay
- chrisg4
- Car Make: Seat
- Car Model: Cupra 1.8T
Soldier510
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Polo 9n3 1.6i Comfortline
Ex Golf V 2.0 Black Magic
Ex Golf IV 1.6
Ex Jetta II Clx
Ex Toyota Corolla 1.3
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
Re: Squeak from engine bay
Rat?
- Kyle
- General
- Registered for: 11 years
- Car Make: Porsche
- Car Model: Adidas TYP 64
- Membership No: 1922
panic-mechanic wrote:Rat?
- chrisg4
- Car Make: Seat
actually there was a rat in there it has since vacated...panic-mechanic wrote:Rat?
Soldier510
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
- Kyle
- General
- Car Make: Porsche
Had an issue with the bonnet touching the fender on my IC. Annoying squeak as well.
- chrisg4
- Car Make: Seat
Update:
I think I found the issue, the polyurethane dogbone mount insert cracked/tore. I was under the impression that the poly mounts don't get damaged?
Soldier510
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
With enough force you can break anything. My dad always said You can even break your finger off in you arse if you try hard enough.
Point is anything can fail.
Lolpanic-mechanic wrote:With enough force you can break anything. My dad always said You can even break your finger off in you arse if you try hard enough.
