What cam and chip for a MK1 2liter
Rishaad Khader
Post by Rishaad Khader » Tue Jul 18, 2017 7:13 pm
Hi guys , please help decide on a set up for my motor.
Basically what to put a cam and chip.
What would be the best set up for daily use.
ADZ
Car Model: Mk2 GTI 16v
Re: What cam and chip for a MK1 2liter
Post by ADZ » Wed Jul 19, 2017 8:24 am
Each individual is different some guys can live with a 288 and some cant stand a 272, you will have to figure out what suits you most people go with 276 estas billet good all round cam good performance if you looking for something daily and not too wild that's your cam also if you running mp9 it would be better mp9 can handle it no issues
02' citi 2L 8v
89' Mk2 1.8 16v GTi
72' Beetle 1600TP
ICE King
Post by ICE King » Wed Jul 19, 2017 8:52 am
:iagree: As above . 282 will also be a option , not as mild as the 276 and not as wild as 288. perfect balance between the two and since no head work and still on mp9.
Rides:
ADZ
Post by ADZ » Wed Jul 19, 2017 8:56 am
oh yeah I'm running the same ADY with a 282 estas on mp9 works 100%
02' citi 2L 8v
89' Mk2 1.8 16v GTi
72' Beetle 1600TP
G 4 LYF 86
Car Model: Golf MK 7 R
Post by G 4 LYF 86 » Wed Jul 19, 2017 9:29 am
I had a 2l 8v with 276 can and a uniq chip it ran great as a every day run around with some great power
Rishaad Khader
Post by Rishaad Khader » Thu Jul 20, 2017 12:26 pm
ADZ wrote:oh yeah I'm running the same ADY with a 282 estas on mp9 works 100%
Was you ideal effected in any way. Correct me if I'm wrong you ideal gets effect when the is overlap with lobes.
ADZ
Post by ADZ » Thu Jul 20, 2017 12:57 pm
yes it was affected, the idle is lumpy but for me I like it, it has never switched off can take off at 1000rpm and it's smooth, if that is a concern then maybe you should look at an estas 272 or 276
02' citi 2L 8v
89' Mk2 1.8 16v GTi
72' Beetle 1600TP
Post by panic-mechanic » Thu Jul 20, 2017 1:11 pm
If you do not want your ideal affected then I suggest you leave your standard cam in. They are ideal for a nice ideal. They have much less of the is overlap with lobes.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
Rishaad Khader
Post by Rishaad Khader » Thu Jul 20, 2017 1:24 pm
ADZ wrote:yes it was affected, the idle is lumpy but for me I like it, it has never switched off can take off at 1000rpm and it's smooth, if that is a concern then maybe you should look at an estas 272 or 276
I don't mind the ideal ,actually like it myself.
Did it burn rich though , thats actual my only concern.
turbowheelchair
Car Model: Golf MK5 2.0 TFSi
Post by turbowheelchair » Thu Jul 20, 2017 2:53 pm
I don't mind the ideal IDLE ,actually like it myself.
JonaDTD
Car Model: 2.0 8V
Post by JonaDTD » Fri Jul 21, 2017 10:47 am
This same question has been burnt to death, then revived, then disected, and then reincarnated, and chopped into tiny pieces and placed in a pizza oven.
TLDR - cam is up to what you can handle, and what you want. I ran a 276 and hated it, went 288 and found it so much smoother.
Also, Estas only - nothing else.
For everything else, there is the search function. Some can handle 288 upwards daily, some people don't like it. Daily generally holds best with a stock car.
Lemon Citi Ride Thread:
1995 Citi - 2.0 8v, headwork, double valve springs, Estas 288, bigger valves, Dicktator, 4-2-1 branch, 50-57mm progressive exhaust.
Ex ladies:
Polo TDi Sportline 2008 9n3 - GTB2268VK, FMIC, Fuel Cooler, A/C Delete, Interior Delete, Sparco Deep Dish Wheel, 12.9 Head Bolts, Race Pipe, 63mm Exhaust, Full Poly Mounts, Coilovers, blah blah blah. Ride Thread Here: SR Tuned BT TDi
Polo 2.0 Highline 9n3 (90kw 175nm) SOLD
Ford Fiesta 1.6 TDCi (RIP)
