VW Rear View Camera (RVC) - no image on display
- Belix
- Car Model: Passat B8
Re: RVC - no image
A kind bloke on www.R32OC.com was good enough to haul out an old camera he had and confirmed the wiring order
Not sure how I'm going to keep the wiring attached without the weatherproof jacket, as it acted as a clip. Anyway, will give it a try this weekend.
- BB-GP
- Car Make: vDubz
- Car Model: 2.0TDi Caddy Alltrack
- Belix
Re: VW Rear View Camera (RVC) - no image on display
Yes, that's the plan. Don't think it will have enough grip. But hopefully...
- BB-GP
- Car Make: vDubz
You get adhesive lined heatshrink
- Belix
No idea it existed. Thanks! Hopefully RS online has some in a big enough size
Re: RVC - no image
Possibly try using some hot glue to create a housing for the individual cables and them some silicone to hold the assembly in place.Belix wrote:A kind bloke on http://www.R32OC.com was good enough to haul out an old camera he had and confirmed the wiring order
or plastic steel epoxy.
- Belix
Finally got plugs from RS. Min order of 5 so have some spare...
Amazingly they were the right ones, although I did have to cut the slight protrusion off the one side
Also got some adhesive shrink tube (3m, used 15cm!)
As the heat shrink does not bend, and to hopefully avoid a future similar issue, I cut the wire opening quite a bit, to let the wires completely clear the housing when the camera moves in and out. It looks big but the action of the camera brings the wires within a mm of the housing
All working again!
If I'd just cut the weatherproof collar off in the first instance, it would have been such a quick fix...
All working again!
- Membership No: 2033
For future reference what were they called / part #?Belix wrote:Finally got plugs from RS. Min order of 5 so have some spare...
Belix wrote:All working again!
Hindsight is always 20/20 .......Belix wrote:If I'd just cut the weatherproof collar off in the first instance, it would have been such a quick fix...
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Belix
sorry yeah
crimp housing / terminal block or whatever you call it:
Amphenol FCI 90311 Series 2mm Pitch 8 Way 2 Row Straight PCB Housing (CRIMP HOUSING MINITEK 8 WAY shows 2x5 but it's actually 2x4)
http://za.rs-online.com/web/p/pcb-conne ... s/6737626/
and
crimp ends
Amphenol FCI MINITEK Crimp Terminal, Female, 30AWG to 26AWG, Gold over Nickel Plating (Crimp Contact Minitek 26-30AWG)
http://za.rs-online.com/web/p/pcb-conne ... s/7142404/
and
crimp ends
- Belix
After the car was at the panel beater, it came back with the same issue.
Wiggling the camera feed wire got a camera display on and off, so I have the same issue again, no doubt a different wire this time.
Suspect I'm going to have to get a replacement camera from carsystems sooner or later. At least they sell just the camera (actually just need the wiring bit) but it's still a big outlay at €214.00.
And judging by their "BESTSELLER" tag, this is common issue, which I will probably have again, even with a new camera, in five or six years...
