VW Rear View Camera (RVC) - no image on display
Online
- Belix
- Car Model: Passat B8
So over the weekend, this started. Or stopped as the case may be...
No image.
When I engage reverse, I hear the motor and the badge tilts, so I don't think it's a power issue unless the feed from the camera to the badge is somehow cut, but it seems unlikely. Also means it's getting reverse signal.
I checked the connector on the back of the head unit and it's seated 100%. Could not see any unseated wires.
So I'm thinking either:
- camera in badge stopped working
- head unit has a issue and is not showing the feed
- wiring between RVC and head unit.
Without a spare head unit or camera, I'm not too sure how to proceed. I don't know how to test either in another way.
In the meantime, I suppose I can at least test there is no break in the wiring...
No image.
Re: RVC - no image
Does vagcom show you that they are ok or is there maybe a comms issue. If say then maybe the control unit not working.
Does the pdc part of it still work ie. Just the camera that is dead?
Online
- Belix
RVC - no image
Thanks Panic! Sorry, forgot - Vcds reports no signal.
PDC still working 100%.
As head unit reporting no signal, would that mean it's unlikely to be the head unit?
Re: RVC - no image
Mmm no my feeling is the camera packed it in.
- Awesum
- Car Model: Tiguan
- Membership No: 999
Re: RVC - no image
Can you test to see if the camera is getting a voltage? If it is then I would test at the head unit plug to see if the signal is coming through.
You can find the pin assignments here: http://www.my-gti.com/529/volkswagen-rn ... ssignments
2019 Tiguan 2.0TDI, R-Line
2019 Polo GTI
Ex 2013 Tiguan 2.0TDI
Ex 2016 Golf VII R, DSG
Ex 2015 Polo 6C GTI, DSG, Pure White
Ex 2014 Golf VII GTI, DSG, Tornado red
Ex 2010 Scirocco 2.0TSi, DSG; Candy White; Revo, 20" RS6 wheels; Coiled looow.
Ex 2010 Golf VI GTI Dsg, Tornado Red, 19's, Revo 2
Ex 2008 Golf V GTI DSG, Riding on 19"s
Ex 2007 Golf V GTI DSG
Ex 2002 Golf IV GTI
Ex 1991 Golf II GTi 2.0 16V
Ex 1991 Jetta II CLi 1.8 8V Exec
2019 Polo GTI
Ex 2002 Golf IV GTI
Online
- Belix
RVC - no image
Thanks awesome. What would I test at the head unit? Seem to remember the input was four wires but I'll use the pin out diagram to see what they are, but how do I check if there is a signal coming across them?
- Awesum
- Car Model: Tiguan
Re: RVC - no image
I'm guessing, but I think you should get milli-volt on the videos wires, when the camera has a supply.
You should test from both sides. 1st the camera side, while plugged into the deck and then the deck side with the plugged in. Also test the continuity of the wires.
Make sure that the camera is getting +12V. I suspect that this might be the problem.
2019 Polo GTI
Ex 2002 Golf IV GTI
2019 Polo GTI
Ex 2002 Golf IV GTI
Online
- Belix
RVC - no image
Got a chance to open the tailgate.
Issue was pretty obvious, yellow wire has broken off right at the camera. Pretty crappy design from VW, the camera movement in and out bends the wire each time it's used so it's bound to break sooner or later.
The badge comes apart so I tried to get to the camera to see if I can repair the wire.
Unfortunately I need a tiny hex screwdriver to get further. However the camera looks like a sealed unit, I assume for weather proofing, so don't know if there is a way I can repair the wire...
Online
- Belix
Re: RVC - no image
www.carsystems.pl stocks a replacement camera for €179 which is better than the €419 for the full badge, but means a wait for the replacement.
http://www.carsystems.pl/vw-rear-camera ... id843.html
- Awesum
- Car Model: Tiguan
Re: RVC - no image
Damn, thats not good.
I would try and repair it myself, even if it means breaking the camera open.
2019 Polo GTI
Ex 2002 Golf IV GTI
2019 Polo GTI
Ex 2002 Golf IV GTI
Online
- Belix
Re: RVC - no image
Good news is that the camera is a separate unit
Bad news is that the wiring harness is clearly not made to be removed. I'd need to rebuild the wiring harness and need new terminals and the weather proofing outer shell that I needed to cut.
Online
- Belix
Re: RVC - no image
You know that feeling when you know you've messed up and it's gonna cost you? I cannot find the correct terminals now, and I cannot reuse them as they got bent when I pulled them out.
In hindsight, I should have just cut the weather proofing off without trying to remove from the camera...
Re: RVC - no image
There is a tag on that harness. Its it not a part number?
Price that.
Price that.
Online
- Belix
Re: RVC - no image
Thanks Panic. Number on the harness fades to nothing, but googling what was left yielded no results.
The connector that was in the camera crumbled when I tried to extract it. Not winning finding the correct terminals or a replacement connector.
And to top it of, the key I made of which pin goes where has gone awol.
So all in all, it's going well! I suspect I'll just have to swallow the cost of the replacement and chalk it up as lesson to be a tad more careful...
- Awesum
- Car Model: Tiguan
Re: RVC - no image
I'm sure that you can buy those repair wires from VW. The connector also looks like a common VW fitting. You might find something similar at a scrap yard and could modify it to fit. Wiring diagrams can be found on Google.
Lots of part numbers and pics here:
http://www.my-gti.com/2837/installing-a ... lf-mark-vi
2019 Polo GTI
Ex 2002 Golf IV GTI
2019 Polo GTI
Ex 2002 Golf IV GTI
Online
- Belix
RVC - no image
Nah, I've been sitting through sites with vw terminals for hours and not found them. Don't have access to ETKA any longer, but not found anything on Google thus far...
Re: RVC - no image
Have you tried places like rs components and communica?
Online
- Belix
Re: RVC - no image
Not tried communica, but RS-Online is a nightmare, they stock a million items, hard to track down what you need without some way of narrowing the results down.
- Membership No: 2033
Re: RVC - no image
Email them pics, or take samples to them ....... I normally phone them and say I don't know what the thing is called, but have a pic can I send to them to have a look. Looks like a standard type connector (just dunno what they are called) Also take a pic of the legend before dismantling.....Belix wrote:Not tried communica, but RS-Online is a nightmare, they stock a million items, hard to track down what you need without some way of narrowing the results down.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Online
- Belix
Re: RVC - no image
Think I've traced the connector crimp bit:
http://za.rs-online.com/web/p/products/7142404/
Looks to be called minitek.
Finding the housing is proving more difficult...not helped by the fact I don't know the actual correct name for it... I think it's called a terminal block, of type wire to board.
This is the closest I've come to finding it.
http://www.mouser.co.za/ProductDetail/A ... TbXELjTSI=
Maybe I can do some plastic surgery on it to get it to fit...
Re: RVC - no image
Check communica or Rs for Molex connectors, they have diffent sizes and pin configurations.
- Awesum
- Car Model: Tiguan
Re: RVC - no image
2019 Polo GTI
Ex 2002 Golf IV GTI
2019 Polo GTI
Ex 2002 Golf IV GTI
Online
- Belix
Re: RVC - no image
Thanks, yeah I know those ones, but those all apply to the connection to the camera harness, not to actual camera, but think I'm on the right track now. Just would love a pin out of the 8 camera pins.
Re: RVC - no image
No picture before you ripped the harness out?
Online
- Belix
RVC - no image
Trouble was I had no way to see how the wires were attached as it was covered with the weather proofing. It gave a bit with a pull so I thought the weather proofing was the attachment. Next tug and all the pins came clean out.
I have estimate of where they go based on their positions after pulling them out, but I'd prefer to be certain.
Found a couple of examples on the net, but in those cases, the black terminal block came out rather than the pins, so they did not have to remove the weather proofing, so no online pictures of the wiring order.
