Polo vivo struggling to start?
- Matthews c!t! :)
Hi there , my aunt has a 2012 polo vivo 1.6i .
It will start in the morning on cold starts
But won't start in the afternoon when it's hot, it just swings over but doesn't start , what must I do?
Re: Polo vivo struggling to start?
Change the water temp sender.
- Matthews c!t! :)
Sorry , where would be located if you know or have a pic?
- georgie
- Car Model: 07 pgti
My wife has the same problem with her 2010 polo 1.4i, so does her colleague. Apparently a common issue on vivo and 6r polo. Some say replacing the fuel pump/relay resolves this. Havent tried yet.
Water temp sender makes more sense though...
07 PGTi
Ex: 11 BMW 320d
Ex: 12 Cross Polo 1.6
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 99 Polo 2.0 16v (ITB's, cams, etc)
Ex: 05 Fiesta ST, 00 Sentra 200gsi, 04 citi 1.4i, 94 Corolla 180i GSE ,92 cti, 73 Escort Mk1 4AGE twincam
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
- Car Model: MK5 Jetta | MK6 GTI
Have the car scanned.
..Does it have a rough idle on cold starts and fluctuating temp gauge?
I replaced my temp switch on my vivo, it did not have any non start symptoms.
My error:
P0116 - Engine Coolant Temperature Sensor 1 Circuit Range/Performance
Intermittent
Measurements: 00000010 27 % -10.0 % 13 km/h 56 °C 422 mbar 700 U/min 7.0 °v.OT
Frequency counter: 1
Driving cycle: 3
Priority: 3
My error:
Intermittent
Driving cycle: 3
Priority: 3
- georgie
Where does the temp switch sit? Cant seem to find anything online.BoraMad wrote:Have the car scanned.
My error:
Intermittent
Driving cycle: 3
Priority: 3
Alos, what are you using to scan your vivo?
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
georgie wrote:My wife has the same problem with her 2010 polo 1.4i, so does her colleague. Apparently a common issue on vivo and 6r polo. Some say replacing the fuel pump/relay resolves this. Havent tried yet.
This. A colleague had the same issue on her 2013, took Dealer a week to figure out its a relay. Worth a look
Upset the Setup
- georgie
Strange thing is the relay sits under the steering column, so not sure how the heat affects it?021Daily wrote: This. A colleague had the same issue on her 2013, took Dealer a week to figure out its a relay. Worth a look
Now to make things weirder, Goldwagen will tell you they dont have a fuel pump relay listed for these cars
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Its sits on the right of the engine in the coolant housing. Just below the air guide. You will see the temp switch as its the only part that has an electrical connection. the switch is grey.georgie wrote:Where does the temp switch sit? Cant seem to find anything online.BoraMad wrote:Have the car scanned.
My error:
Intermittent
Driving cycle: 3
Priority: 3
I use OBDEleven, very useful.
- georgie
Thank you sirBoraMad wrote: Its sits on the right of the engine in the coolant housing. Just below the air guide. You will see the temp switch as its the only part that has an electrical connection. the switch is grey.
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
On the right of the engine if you stand in front of it yes. But basically all material describing engine side is as if you were sitting inside the car looking forward thus that making it the left of the engine. Sorry just being pedantic.
- georgie
This one?BoraMad wrote: I use OBDEleven, very useful.
http://www.bidorbuy.co.za/item/27348766 ... apter.html
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Yes, thats the device but i would rather buy it from https://obdeleven.com themself. much cheaper.georgie wrote:This one?BoraMad wrote: I use OBDEleven, very useful.
PM me your number, you can bring your polo around.. i'll do a scan.
- georgie
Shot man! Its my wife's car. Will contact you if I need to bring for that scan. Interested in getting one of these dongles for myself though. I still have the old vag-com diags cable.BoraMad wrote: Yes, thats the device but i would rather buy it from https://obdeleven.com themself. much cheaper.
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
- Car Model: Polo vivo 1.6 GT
Boramad can u get live data to display? On a vivo
using the OBDeleven
Yes, I have the pro version. Its not as graphical as VCDS but the all the info is available.brandingo13 wrote:Boramad can u get live data to display? On a vivo
You are able to perform output test as well.
- Car Model: JETTA MK3
My polo 6 tdi used to do that when its hot it cuts out and u have to wait for the fuel pump relay to cool off before you can start it again then runs a little and stall again wouldnt start when hot. Cold starts no issues same time.did a scan and gave maf error replaced the sensor and the relay no issues for a year now hot or cold. Not sure what maf had to do with the relay heating up maybe just coincidence ek weet nie.
Audi A1 7 speed STron
auto Jazz 03
auto Jazz 03
- Registered for: 5 years
@Matthews @Georgie did cha ging the temp sensor sort out the starting problem? I have tge same problem with my polo vivo 2010
Good day
It partially solved the problem because it randomly struggles to start but I think I may have to get the original water temp sender unit from the agents,the one I have I bought from Goldwagen.Before I replaced this it was battling to start every day,now it is at least once every 8 weeks.
- Registered for: 2 years 4 months
I just want to know the best diagnostic software for polo gti
Vcds by rosstechClemyD wrote:I just want to know the best diagnostic software for polo gti
