2011 VW Polo Cross TDI
- Static-TDI
- Car Model: Polo 6R TDI
Hi Guys
I purchased myself a Cross Polo a month or so back and I am having an issue with noise coming from inside the car, I have noticed that you can hear it best in the leg space under the glove compartment. It sounds like a pulley that's struggling to turn and the car was sent back to the dealers to be checked out. They said they could not find any issues in the engine bay, now I'm starting to think it may be something to do with the aircon. The sound does not speed up when i drive, but it is louder sometimes and then sometimes very soft.
I don't know what to do regarding finding the issue?
Ill see if there is a way to upload the audio, i just need some advice
1990 Golf MK3 1.8 GSX - SOLD
2005 Golf MK1 Citi Rhythm 1.4 - SOLD
2006 Golf MK1 Velociti 1.4I RIP
2010 Polo 6R 1.6 TDI - Sold
2011 Polo Cross 1.6 TDI
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Re: 2011 VW Polo Cross TDI
Press the aircon recirculation button and see if the noise starts or stops, if it does check under the dash while pressing the button there could be something blocking the flap.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- Static-TDI
@AlexTDi
Thank you for the reply, I had a look now under the dash when pressing the circulation the flap seems to open and close without any problems. The noise is there when the aircon is off and even when the vents/airflow is on the 0 setting. I did however notice that the sound seems to stop when the aircon is turned on, or maybe I just can't hear the sound when it's turned on, I'll just check on this again when i get home this afternoon.
Any other ideas?
Any other ideas?
- AlexTDi
No, the interior fan & cabin filter all sits that side so I suspect it can only be that. unless it is actually on the engine side and you hear it through the firewall.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Static-TDI
Thanks ill check again later. The engine was checked out twice by the dealer's mechanic and they said there is nothing they can find that would be the cause of the sound.
I have uploaded the audio clip if anyone wants to listen, just turn up the volume to hear it seeing as its a bit soft.
http://www.filedropper.com/131020161645_1
- Static-TDI
Okay so i have not solved the above mentioned issue, but i have another question, after i turn off my polo and i remove the key i hear 4 clicking sounds coming from the engine bay . . . Its always four in a row and its almost like a "tik, tok, tik ,tok".
Anyone else who might have come across this before?
- Shadows101Fall
It's probably just solenoids/relays that's going through their shut down process, I wouldn't think much of it.
I buy broken/smashed/written off cars
Current: 2005 Alfa Romeo GT 1.9 JTDm
Ex: 2014 Nissan NP200 1.6i - meh.. Sold
Ex: 2000 Alfa Romeo GTV 3.0 Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=197077
Ex:1980 2 door mk1 build thread Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=192831
Time bomb?
- Membership No: 2033
Check the recirc valve, same issue on the Mk5. Even with blower / aircon off you ended up with the noise. The valve / worm gear is faulty and causes the noise. Also that side of the cabin.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Static-TDI
@Howie-WP
thank you for your feedback, I just want to confirm if its a "recirc valve", I could not find anything on google and i would like to send the dealer an email to ask if they will check if it maybe the problem as you described
- Static-TDI
Hi All
So after almost a year, I did not care much about the noise on the car, but on my way to work today I drove past a repair shop and asked one of the mechanics to just have a quick listen to the sound and let me know what he thinks. He then told me the sound is coming from my aircon and its caused by the circulation of the aircon gas and unfortunately, there is nothing they can do to fix it.
so, in short, the noise will be there forever. . . .
- georgie
- Car Model: 07 pgti
I have a similar whining noise coming from my ac as well. Its more of an annoyance than an actual problem at the moment. Apparently its quite common and Barons has no idea how to fix it. AC specialists should be able to sort it out though. I stopped at a Radio Autosonic once to test and they said it could be a faulty expansion valve but advised me to get a second opinion. Havent gotten around to it yet. Other guys have said that changing one of the tensioners/pulleys resolved the issue for them. Not sure of details.Static-TDI wrote:Hi All
07 PGTi
Ex: 11 BMW 320d
Ex: 12 Cross Polo 1.6
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 99 Polo 2.0 16v (ITB's, cams, etc)
Ex: 05 Fiesta ST, 00 Sentra 200gsi, 04 citi 1.4i, 94 Corolla 180i GSE ,92 cti, 73 Escort Mk1 4AGE twincam
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
- georgie
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
- 323bp
- Car Model: B7 Avant
- Membership No: 1887
Has a noise coming from there. Turned out to be the engine mounting
Sent from my HUAWEI NXT-L09 using Tapatalk
Current : Audi b7 avant 2.0TDI
Current : VW Polo TDI - intake, straight pipe and and...
Ex : 1968 Austin mini 1000
Ex : FORD Figo Trend
Ex : VW Polo GTI DSG
Ex: Opel Corsa utility
Ex: 323 BP05 , Spitronics management , Powerflow exhaust
16.84 @131 kph
@adamtas1024
Debian cause i'm a cheapskate
- Static-TDI
I'm going to find an RMI dealer to have a look at the AC seeing as I still have a 1-year warranty on the vehicle so ill would like to get it repaired. It's just difficult to get a repair quote when you're not 100% sure what the problem is.
I also noticed in this week there is now a soft whistling noise also coming from around the area.
