polo 1.4 intermediate rattling crackling noise under load
- Car Make: vw polo 1.4
- Car Model: 2004
hi guys.need sum help.my 2004 polo gvs off a rattling crackling noise under load intermediately.on idle theres no noise,even if i rev the car up on idle thers no noise only under load this noise appears,basically on low revs cos on high revs under load theres no noise.help plzzzzzzzzzzzzzzzz
Re: polo 1.4 intermediate rattling crackling noise under loa
sounds like possibly detonation.?
- Pieta
- Car Model: 04 A4 1.8T 6spd S-Line
- Membership No: 1909
+1 For detonation
Pieter "Pieta" Oberholzer
-04 Audi A4 B6 1.8T
BT In process
Biltein + Eibach Sportline
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- Car Model: 2004
Will that b that the timming is off
Kind of hard to commit on noises without hearing it.
- Car Model: 2004
K i eventually did a diagnostic and it pikd up faulty knock sensor.so i bowt a set off new plugs and a knock sensor from goldwagon.i installed the sensor i did thighten it up with a wrench.i did nt torque it.as i dnt knw the torque specs for polo.the ping as gotten alot better bt is still der.any idea if the noise is there cos off not torqueing it?
- Pieta
Check your timing...calvinmodley wrote:K i eventually did a diagnostic and it pikd up faulty knock sensor.so i bowt a set off new plugs and a knock sensor from goldwagon.i installed the sensor i did thighten it up with a wrench.i did nt torque it.as i dnt knw the torque specs for polo.the ping as gotten alot better bt is still der.any idea if the noise is there cos off not torqueing it?
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
I've heard many times that knock sensors should be torqued to spec, and that it is very easy to over-torque them, which can lead to failure. But this is only forum feedback of 15 years, not my own experience.
After checking the timing, do another diagnostic.
What will checking the timing help? I am assuming this is not the regular old 1.4 8v but the later 16v job that has 60-2 and no distributor?
That is if it is a 2004 year which is the 9n jobs?
- Car Model: 2004
Yes it a 9ñ polo.and im by a mechanic nw who sd the gearbox timming is off will that be correct?
Get a different mechanic or please let him give us a detailed description of how to time a gearbox.
- Pieta
Apologies,panic-mechanic wrote:What will checking the timing help? I am assuming this is not the regular old 1.4 8v but the later 16v job that has 60-2 and no distributor?
Thought it was a 6N MP9 jobbie...
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- Car Model: 2004
K check timming and set it according to the marks.did a diagnostic no faults.but the pinging sound still der wen accelerating under load
Ok for the dake of clarity. What engine is this exactly? Engine code or take a picture please.
- Car Model: 2004
Okmso that is a distributorless engine with 60-2 pickup. How exactly did you set the timing.
You can maybe look at it but that is about it. Unless there is a piggyback installed in which case that mapping is most likely causing the ping.
If it is pinging you are Really hearing and this is a stock engine then possibly you are starting to hear the beginning of a possible head gasket failure.
When the gasket blows between two cylinders it will overpressure the one from the other side.
But again - noises are subject to the person hearing and describing it.
- Car Model: 2004
I even changed headgasket lastweek.it is a stock engine.and timming was done with the marks on the covers.
- amstel18
- Car Model: Tiguan Allspace
Why did you change the headgasket? Sommer net?
Did you do a compression test before and after? Did you do a CO test on the cooling system to establish a headgasket problem?
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Car Model: 2004
Assumed a blown head gasket was causing the pinging.
- Pieta
Was the gasket blown?calvinmodley wrote:Assumed a blown head gasket was causing the pinging.
Did they skim the head?
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- Car Model: 2004
Any idea of a good mechanic in durban to have a look at my car
Again i ask a simple question. How did you set timing?
Are you talking about valve timing?
I am talking about ignition timing, not the same thing........
Cam timing is not what causes pinging.
Did they skim the head? How much?
- Car Model: 2004
Nope head was not skimmed.and thr mech set the timming.
- Donavan
calvinmodley wrote:Yes it a 9ñ polo.and im by a mechanic nw who sd the gearbox timming is off will that be correct?
Man I laughed at this.
Probably one of those guys that will tell you the head light fluid needs topping up aswell......
Audi A4 B8 2.0T - Daily
- Car Model: 2004
Leav the laughter and help plz
