Golf 3 gear selector problem
- dcmk4
- Registered for: 10 years
- Car Model: MK7 GTi
Recently I've been having an issue with my golf 3 gear selector getting stuck in reverse.
It goes into all gears smoothly however when you try get out of reverse with the engine on or off and with the clutch in or out.
When trying to get out of reverse the selector has a lot of play and almost seems like it's in neutral as you can almost move it into first but it's still locked in reverse.
I thought it may be selector bushes but haven't had the time to look further into it.
Any input will be appreciated.
Re: Golf 3 gear selector problem
Undo the links form the gearbox and try to move it there. If still hard then it's in the box.
If not it's an adjustment in the links.
- dcmk4
Thanks for the info Panic, I'll have a look at it this evening. Could it possibly be clutch related too or would that be all the gears?
Online
- Membership No: 2033
Would have thought clutch would be all gears....DCmk3 wrote:Could it possibly be clutch related too or would that be all the gears?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- dcmk4
Bad news it that case. I disconnected both linkages attached to the box while I had the car in reverse and it's a proper fight to try and disengage reverse but I can't ever completely get it out of gear by hand.
- dcmk4
I am going to assume this detent bolt should not be coming apart and actually coming out of the "nut/housing" when you point it downwards?
- dcmk4
Such a small part causes such a large problem, trip down to Goldwagen and reverse is no longer an issue.
hi ...I'm not very technical..today i damaged this nut that holds the little ball inside when i to put gearoil in...so i got it loose ith 24 rachet and replaced the gearoil...but i did;nt know i shouldnt try to tighten it too much..where can i find this and how much does it cost...
i drive a 1.3 chico 'm not very technical..today i damaged this nut that holds the little ball inside when i to put gearoil in...so i got it loose ith 24 rachet and replaced the gearoil...but i did;nt know i shouldnt try to tighten it too much..where can i find this and how much does it cost...
- Sean Trollope
- Car Make: VW. Hyundai.
- Car Model: Citi golf. Hyundai i10
Goldwagen. They are in expensive.
Why on this living earth would you take the gear detent out to fill oil. there is a massive hole on the side of the gearbox that is meant for that. or even pull the speedo drive out if you have to work form the top.
