Bulb failure/ error light
- Registered for: 10 years
- Car Model: Polo 9n3
Hi all. I recently upgraded my lights on my 2012 Polo 6. Upgraded the headlights and fogs to HID and changed all the park lights to the super white bulbs. Everything is working 100% but I notice the bulb failure or error light has popped up on my cluster. Any suggestions on how to clear this or what could cause it. Please assist guys. Thanks
Hope I posted this in the right section.
- Tander
- Registered for: 15 years
- Car Make: Seat
- Car Model: Leon Cupra
- Membership No: 1713
Re: Bulb failure/ error light
Hi,
Your car has a system called a CANBUS. Basically its a communication system for the car and it knows whats going on with its electronics etc. This includes detecting if there is a faulty a bulb. Since you fitted aftermarket bulbs, the computer won't pick them up correctly and thus, you get a build out error. You will need to replace the offending bulb(s) with whats known as error-canclening bulbs or canbus friendly bulbs. Your supplier of the bulbs you got should have the correct stuff. Otherwise, Jabba off these forums will be able to help you out with the correct type of bulbs.
Good luck.
Good luck.
2008 SEAT Leon Cupra - Banshee
Exes:
2006 Polo 9N3 - 1.6i
2003 Citi.com 1.3
2003 Opel Corsa Lite
Thanks so much man. I will check if that's the problem, hopefully it is that and nothing major
- Neuk
- Treasurer
- Membership No: 806
In short, the HID kit you have most likely has a lower resistance than the standard bulbs, leading your cars ECU to believe that the bulb is out. As Tander says, you will need CANBUS friendly HID kits...
- TimeShifter
- Car Model: 2012 Mk6 GTi
It's the other way round, the HID's have a higher resistance hence drawing less current which in turn triggers the blown bulb due to the lower current drawn. That's why those "canbus" friendly bulbs have an additional resistor connected in parallel to draw more current. Something to watch out for is that those resistors can get very hot which have caused some cars to set alight.Neuk wrote:In short, the HID kit you have most likely has a lower resistance than the standard bulbs, leading your cars ECU to believe that the bulb is out. As Tander says, you will need CANBUS friendly HID kits...
2012 VW Golf Mk6 GTi
- Neuk
- Treasurer
Woops, I wonder why I thought they had a lower resistance, they do use less power/energy?TimeShifter wrote:It's the other way round, the HID's have a higher resistance hence drawing less current which in turn triggers the blown bulb due to the lower current drawn. That's why those "canbus" friendly bulbs have an additional resistor connected in parallel to draw more current. Something to watch out for is that those resistors can get very hot which have caused some cars to set alight.Neuk wrote:In short, the HID kit you have most likely has a lower resistance than the standard bulbs, leading your cars ECU to believe that the bulb is out. As Tander says, you will need CANBUS friendly HID kits...
- TimeShifter
Yip, they normally 35W if I recall correctly whereas the normal bulbs are 55W.Neuk wrote:Woops, I wonder why I thought they had a lower resistance, they do use less power/energy?TimeShifter wrote:It's the other way round, the HID's have a higher resistance hence drawing less current which in turn triggers the blown bulb due to the lower current drawn. That's why those "canbus" friendly bulbs have an additional resistor connected in parallel to draw more current. Something to watch out for is that those resistors can get very hot which have caused some cars to set alight.Neuk wrote:In short, the HID kit you have most likely has a lower resistance than the standard bulbs, leading your cars ECU to believe that the bulb is out. As Tander says, you will need CANBUS friendly HID kits...
- Tander
- Car Make: Seat
That's correct. Main beams with normal is 55w and the HiDs are 35w.TimeShifter wrote:Yip, they normally 35W if I recall correctly whereas the normal bulbs are 55W.Neuk wrote:Woops, I wonder why I thought they had a lower resistance, they do use less power/energy?TimeShifter wrote:It's the other way round, the HID's have a higher resistance hence drawing less current which in turn triggers the blown bulb due to the lower current drawn. That's why those "canbus" friendly bulbs have an additional resistor connected in parallel to draw more current. Something to watch out for is that those resistors can get very hot which have caused some cars to set alight.Neuk wrote:In short, the HID kit you have most likely has a lower resistance than the standard bulbs, leading your cars ECU to believe that the bulb is out. As Tander says, you will need CANBUS friendly HID kits...
Exes:
2003 Citi.com 1.3
Just confirmed with my supplier and he says that the HID kit itself are canbus friendly and so are the park lights itself. Are there any other factors that could cause this and what's th safest way to sort it out without my car catching alight
- Membership No: 2033
Clearly not.....else you would not be getting a error (unless you have a bulb out)Prinzo wrote:Just confirmed with my supplier and he says that the HID kit itself are canbus friendly and so are the park lights itself.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
Make sure all the clips and wires are fully secured , fitted normal Blue Ultras and had one bring up error
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
- Amith11
- Car Make: DUH !!!
- Car Model: MK7 GTI
- Membership No: 1545
Howie-WP wrote:Clearly not.....else you would not be getting a error (unless you have a bulb out)Prinzo wrote:Just confirmed with my supplier and he says that the HID kit itself are canbus friendly and so are the park lights itself.
Who is the dealer if you dont mind me asking ?
I am with Howie on this, either its not friendly or you have an electric issue with a light out or wire etc faulty
MK 7 GTi
(Daily)
amith.singh@icloud.com
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk4 GTI .:R (True Love)
MK3 Cabriolette 2.0l Exec
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
(Daily)
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
- Tander
- Car Make: Seat
Almost definitely not canbus friendly bulb.
You can double check by simply installing the original bulbs. If error disappears - you know where the issue is then. The HiD bulbs.
Exes:
2003 Citi.com 1.3
- Amith11
- Car Make: DUH !!!
Tander wrote:Almost definitely not canbus friendly bulb.
MK 7 GTi
(Daily)
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
(Daily)
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
Cool guys. Thanks for all the replies. Just been so hectic with the festive season. Compliments of the season to everyone. When I sort it out then I will let you guys know.
Hwsit. Same story here after I changed tail light bulbs and replaced them with led bulbs. Any idea where I can get Canbus friendly red tail light bulbs in Durban?
