Sunroof service
- Crawler
- Car Model: 9N3 Polo TDi
- Membership No: 1358
Sunroof service
So I got to my car the other day after warrior race and the roof lining was wet, assuming the sunroof is either leaking or the drainage is blocked.
I am going to see what I can do in regards to the drainage, check it and clean it.
Called Webasto, they will not touch a factory fitted unit.
Who else can I try on the east rand?
Thanks guys
Thanks guys
CW Polo TDi Sportline
- Iry-gp
- Registered for: 12 years
- Car Model: Mk5 GTi
Re: Sunroof service
I was just gonna start a Thread on this topic until i saw yours.
Dont mean to Thread jack.. i wanna find out how to clean the sunroof Drainage system as well but for G5 GTi
There is no leaks or anything currently but just would like it to be cleaned as a piece of mind before a leak does start.
Anyone has a DIY on cleaning the Sunroof Drainage system on MK5 Gti ?
Street Racing is boring except when a car is going at least 140km per hour upside down.
Current Ride: E46 M3 Vert
Ex-Rides:
Golf 5 GTi k04 (Bagged and tagged)
Honda Ballade Vtec
Polo 1.6 (1st Veedub)
Honda Ballade B20 Vtec
Honda Ballade 160i
BMW e36 318i
Ex-Rides:
Honda Ballade Vtec
Honda Ballade 160i
BMW e36 318i
- Crawler
Re: Sunroof service
Webasto technical told me over the phone, in all 4 corners there is apparently a little hole, use compressed air to blow them out, then pour water in the tray to see if it filters away.
- Registered for: 15 years
- Car Make: VW Polo
- Car Model: Sportline 1.9 TDi
Re: Sunroof service
I have been trying to get this fixed a well.. The way that VW supposedly services these drains is they use a strong cable like the an speedo cable and they push it through the drain holes. there is 2 at the front and and 2 at the back of the sunroof. Below is the a diagram & write up of what it looks like.I haven't had the chance to test it out though so let us know what come of it.
1 - Water drain hose
2 - Water drain valve
3 - Cover
Note
For cleaning, a locally manufactured tool made from a speedometer inner cable, approx. 2300 mm long is recommended.
Front water drain hoses:
The front water drain hoses → Item are routed along the A-pillars and finish at the plenum chamber. Cleaning is done from the sunroof panel aperture.
Note
3 - Cover
Note
Note
VW Polo 1.9 TDi
VW Caddy 2.0 8V
Ex-Rides:
2004-Polo 1.6
1997 Toyota Corrolla 1.6i Exec
1.8 Golf Mk1
VW Beetle 1600 Twinport
VW Polo 1.9 TDi
VW Caddy 2.0 8V
Ex-Rides:
2004-Polo 1.6
1.8 Golf Mk1
- Car Model: 9n3 Comfortline ROX
Re: Sunroof service
its like you guys read my mind, left my car in the rain during the week and the roof was a bit wet on one side, i asked VW and they said to also buy a tape that is taped around the roof where the grass rests when it is closed, i remember removing it when i was removing the roof vynil as i thought it was the remainder of the sticky residue, i will also try this one thanks guys
Ride Thread...
POLOROX...
FK Streetline COILOVERS
18" BBS LM REPS
HID 6000k HEAD+FOGS
Sony HU+ STARSOUND AMP+ PIONEER SUB
GLOSS BLACK CUPRA LIP.
Ex: VW CitiRox _Reflex Silver
POLOROX...
18" BBS LM REPS
HID 6000k HEAD+FOGS
- Registered for: 10 years
Re: Sunroof service
I've inquired about servicing an OEM medium sunroof at VW
All they do is re-grease the rails and check if it operates flawlessly and voila, R280 later. I too need to sort out my sunroof (unblock the drainage lines)
I however got the worse end of the stick, could this be the cause of a blocked drainage line?
The interior lights went to heaven. Upon checking the fuses, i discovered that non of them popped, all were still fine, but when testing the probes with a test light it didn't work.
I've went as far as hosing the sunroof area to check for water mark traces between the fuse cover and door but its always dry.
I was told the drainage lines runs alongside the front door card area, if that's the case, is that the reason for the havoc, as per pic attached. Is this true?
- Car Make: VW Polo
Re: Sunroof service
@ Chevy this most definetley could be die to blocked drain. simple test would be to pull the front side cover where the small tweeter is and check the pipe that runs there..then slide the sunroof all the way back, get a small jug of water and pour some water slowly down the front end of the sun roof(you will see a black tray there with drain holes as shown in above diagram. see where water runs out from.
VW Polo 1.9 TDi
VW Caddy 2.0 8V
Ex-Rides:
2004-Polo 1.6
1.8 Golf Mk1
VW Polo 1.9 TDi
VW Caddy 2.0 8V
Ex-Rides:
2004-Polo 1.6
1.8 Golf Mk1
- Crawler
Re: Sunroof service
@ Chevy - I called a guy in alberton - Johan - he wanted R750 for the "service" and when I mentioned it might leak/be block drain he added another R1000 to the price
- Crawler
Re: Sunroof service
So it happened again, this time on driver side
Water running next to the fuse box can never be a good thing
Anyone know of someone good with sunroofs at a decent price?
- 2dean-zn
- Car Make: golf
- Car Model: mk1
Re: Sunroof service
if the drainage is blocked, can water still get into the car if the sunroof is closed?
my polo also leaks on the left side but i assumed it was the windscreen
current rides:
07 mk1 MP9 2lt 8v - 155whp @ ODR
07 polo gti 9n3 - 155kw, 344nm - dyno'd in 4th
________________________________________
ex:
98 candy red mk1
97 golf 3 vr6
04 runx
87 honda ballard
- Crawler
Re: Sunroof service
Mine was closed both times and stil lining is wet, the water gotta push back up or something and then pool up
Need to get it sorted and then clean roof lining proper
- 2dean-zn
- Car Make: golf
- Car Model: mk1
Re: Sunroof service
there was a puddle of water on the passenger side floor on my car so after it rained, even when i wash the car this happen. im sure a blocked drainage cant cause so much of water to come in
current rides:
ex:
98 candy red mk1
97 golf 3 vr6
04 runx
87 honda ballard
- georgie
- Car Model: 07 pgti
Re: Sunroof service
I cleaned out the drains on my jetta the other day, was very easy.
Go to checkers and buy 10 meters of curtain hanging wire for around R20. Lube the first meter or so with sunlight and feed it through from the "nipples" until they come out at the drain holes by the sunroof. You might not be able to see this for the rear sunroof drain holes, but just feed the cable as far in as you can. I'm going to trim about an inch off each of the 4 nipples so that the water flows through easier.
On the jetta, there are drain holes in each corner of the sunroof. The front 2 come out close to the door hinges, the rear 2 are under the car at the back on either side. Should be similar on the polo.
07 PGTi
Ex: 11 BMW 320d
Ex: 12 Cross Polo 1.6
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 99 Polo 2.0 16v (ITB's, cams, etc)
Ex: 05 Fiesta ST, 00 Sentra 200gsi, 04 citi 1.4i, 94 Corolla 180i GSE ,92 cti, 73 Escort Mk1 4AGE twincam
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
- Crawler
Re: Sunroof service
Thanks georgie, going to give this a go ASAP
2dean-zn - puddle water sounds hectic - maybe a grommet in firewall is missing or leaking
- Car Make: Landrover
- Car Model: Freelander
Re: Sunroof service
hey guys,
do you know of anybody in CT that services sunroofs besides webasto ?
Ex : Vr6
Ex : MK2 Gti 1.8 16v
Ex : Gtx 2l 8v
Ex : Velociti 2l 16v
Ex : Polo 1.4i
Ex : MK2 1.8 8v
Ex : Gtx 2l 8v
Ex : Polo 1.4i
Ex : MK2 1.8 8v
- Crawler
Re: Sunroof service
I only found 2 holes in the front
Passenger side the wire goes in about 30 cm and the driver side about 100cm - def something blocking it and no way of pushing it open
Wills trip A Pillars and see if I can see anything
where are they suppose to end? maybe try from that side as well
