Hi Guys,
A friend of mine has a 1995 citi shuttle. He has just filled up his tank and an airbubble or vacuum of some sort has got into the system. The a/c fuel pump is working fine but when the bubble creeps up it is working overtime to try and get the fuel in. Do you guys know of anyway to try and get rid of this vacuum without removing the pump.
Eren
Help! air lock - Airlock in fuel tank
- Registered for: 21 years 5 months
- Registered for: 21 years 4 months
Hey BL,
My girlfriend had the same prob with her shuttle, would fill da car up & den it would struggle along, cutting out sometimes.
The problem is that there is a vacuum, not sure how its caused, but that was the root of the problem. Fixed it by drilling a small hole into the fuel cap, to get rid of the vacuum. Since then, theres been no problems!!
Not sure if its the best way to fix it, but it worked anyway. Hope this helps
Red
Red
Ex's: 2006 Polo 1.6 (stolen), 1997 Corsa 130i, 1991 Golf II GTi (The Falcon), 197X SP1600 Beetle
- andredp
Hey guys
If drilling a small hole in the fuel cap helped, the problem is most likely that the tank overflow/breather pipe is blocked. Clearing the blockage from this pipe should solve the problem.
Andre'
Andre'
Driving: 2006 Jetta 2.0 TDi Sportline
Upgrading: Lotus 7 replica - http://www.locostformula.co.za
Racing: Lotus 7 replica racecar - Ford bakkie engine with plastic inlet manifold
Ex: Driving: 2001 Caddy Club, Citi Sonic, MKI 2 Door - 2L with ITBs tamed by PRS2, Toyo Corolla, MKIII Jet CLi, MKII Csl 1600, then 1800, then ..., MKII Gti 8V
- Car Make: Ford
- Car Model: Ranger
- Membership No: 458
I have the same problem. My machie checked and cleared the breather pipe and I still have the problem. My sisters Mk1 also had the same thing and it was the gravity valve that was stuffed. the previous owner of my car, tryed to be a cheap ass and took the rubber seal off the fuel cap so evertime I fill up, petrol pours out of the side of the car.
- Senna
- Car Make: VW,BMW
- Car Model: MK5 GTi/CrossCaddy/325iS
- Membership No: 3101
Re: Help! air lock - Airlock in fuel tank
did any of you manage to sort out the airlock problem.
- TimeShifter
- Car Model: 2012 Mk6 GTi
It would be interesting to see if any of those guys from 17 years ago are still here
Sent from my SM-G975F using Tapatalk
2012 VW Golf Mk6 GTi
- NHB_R
Surely the air is out by nowTimeShifter wrote:It would be interesting to see if any of those guys from 17 years ago are still here
